![]() | Home > Maintenance & Mods (L322) > Tool to remove badge decor |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35652 ![]() ![]() |
fishing line is popular.. ... - .- -.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Im sure someone will be along with some tips soon enough... But for now, DON'T just put something behind it to prize it off sir as you will dent the boot quite badly pulling it off! Very sturdy badge on a thin skin of metal! |
Hairdryer at the hot setting and keep moving it along the length of the badge until it gets nice and warm, then gently ease the badge away from the bodywork. If it doesn't come away with reasonable force/ease then reheat and try again |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
took off my boot lettering with a toffee wheel and credit card. but as Craig said the lower tailgate i much thinner. I did take my Vogue lettering off and replace it with Titan lettering rather than brunel, used a small 6' ruler flat against the boot and slowly and gently eased it behind the letter keeping it flat against the boot to spread the pressure.
scwilson Member Since: 15 Dec 2014 Location: Dorset Posts: 240 ![]() ![]() ![]() |
Thanks for the tips all! |
Pop it into a bodyshop whilst your passing and ask it someone wants to remove it for a tenner? |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
As 47p2 but use fishing line or dental floss. Travelling around in circles again. |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
easy enough :
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Craig, That's no guarantee it will go any better than doing it yourself, if they are heavy handed they'll do the same damage. My advice is DIY, heat it up, slide a credit card behind and gradually side to side motions will start moving it, then use the toffee wheel to get rid of the glue. Discovery 4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 Hard Top *Gone:L462 D5 HSE LUX, L663 Defender 110 HSE, Discovery 3 HSE, 2014MY Range Rover Sport 5.0 Supercharged AB Dynamic; L405 Exec Vogue SE 4.4, 5.0 Supercharged Autobiography, Defender TDCi XS CSW, Defender TD5 HT, Vogue SE TDV8, Vogue TD6, RRSport SC 4.2V8, Classic 3.9 Vogue Auto, Land Rover Series 3 SWB |
Dental floss to cut the badge off and then soak the glue residue in either white spirit or WD 40 and wipe off.
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
carb cleaner or electrical contact is good for glue removal , small spatula like you fry eggs with is good for leverage when warm |
