Home > Technical (L322) > access height?
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
access height?
hi guys
am away at the mo, and need to know what the access height is of the RR? can anyone enlighten me?
cheers
Post #302237 1st Jan 2015 6:41pm
From below or above ? or do you mean from wheel centre to lower edge of wing ? .
Post #302240 1st Jan 2015 6:49pm
andyleeds
Hi joe, no I mean when you lower the vehicle to get into car parks etc....
Cheers
Post #302244 1st Jan 2015 7:03pm
Around 1865mm plus or minus a bit. I did measure mine once but can't find it on search. Where are you trying to fit it in? There is nothing that can't be fixed with a hammer😜😜
Post #302245 1st Jan 2015 7:09pm
A Overall width 2 216 mm 87.2 in
Overall width (mirrors folded) 2 034 mm 80.1 in
B Overall height
- Access height 1 820 mm 71.7 in
- Motorway height 1 840 mm 72.4 in
- Standard height 1 865 mm 73.4 in
- Off-road height 1 913 mm 75.3 in
Post #302246 1st Jan 2015 7:15pm
RiccartonRR
'kin 'ell - I didn't know they were so big Very Happy
Off to check how an L322 compares to a D3 now Thumbs Up
Ok - the L322 is slightly wider and slightly lower than the D3 (1" either way) but it's 5" longer Shocked The D3 is a 7 seater with adult sized rear seats so where's the 5" gone?
Post #302247 1st Jan 2015 7:27pm
I think it tells you on the sun visor does it not?
Post #302248 1st Jan 2015 7:34pm
Weegie
Mine has 1.93 metres on the sun visor with the roof closed. The handbook gives a different figure? Confused John
GAP iiD BT
Post #302249 1st Jan 2015 7:43pm
andyleeds
Yep, it doesn't give the height when on access height...... So does that figure include aerial ?
Post #302277 2nd Jan 2015 6:31am
Weegie
According to the accompanying diagram yes it includes aerial height. John
GAP iiD BT
Post #302280 2nd Jan 2015 8:32am
from the owners manual,
Post #302284 2nd Jan 2015 8:46am
andyleeds
Can the access height be lowered further with one of those tool thingys?
Post #302631 4th Jan 2015 10:40am
andyleeds
Post #302633 4th Jan 2015 10:41am
For shipping.
ebajema wrote:
There is a special transport or delivery mode that you can activate with the Faultmate so I assume the IID can do the same (as the mode is in the car ECUs). It lowers the car to the bump stops, making the suspension very "rigid".
Post #302651 4th Jan 2015 11:29am
Yeah if you have a tool to de-pressurise the system I think it gets you another cm or two but not much.
Also don't forget the non NAV equipped FF's don't have the roof mount aerial as the roof mount is for the NAV, the radios and TV are done in the rear quarter window antennas Smile
To be honest only once have I caught the GPS antenna and that was a very light touch at the Arndale centre car park and the attendant said he had reported it as it had dropped down below the max height over time by a cm or two... I was fine inside the car park and had 2" in access mode Evil or Very Mad Evil or Very Mad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #302664 4th Jan 2015 12:24pm
