![]() | Home > Technical (L322) > Issues after Torque Converter replacement[Verdict added] |
Shogo Member Since: 01 Jan 2015 Location: Sweden Posts: 61 ![]() ![]() ![]() |
Hello !
Thanks for the poll replies, Could you specify your details ? |
MrP Member Since: 28 Apr 2010 Location: West Sussex Posts: 471 ![]() ![]() ![]() |
For what its worth - my 2003 4.4 petrol vogue had the classic TC symptoms - oil had never been changed but no metal shaving in it when checked.
vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332 ![]() ![]() ![]() |
Had ours reconditioned by JAP when I did the engine swap. The previous owner said there were no issues with the gearbox.
Robert Member Since: 25 Oct 2011 Location: Perigueux Posts: 2289 ![]() ![]() ![]() |
On a 2002, I had, they replaced the TC and after that the car still had this caddlegrit sound and strange rpm behaviour. Turned out that they did not do a full oil flush of the gearbox AND the whole system. Had that done, including the filter and it ran great afterwards. Had no probs what so ever |
Tried to take a video of it today.
Not very enjoyable update this.
A full gearbox and system flush is about 7 ltr I think, next to that let them flush it with clean oil, empty again and fill the system up. Have a look in the wiki
Hello again..
Verdict from garage
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 ![]() ![]() ![]() |
Yes if the oil cooler for the gearbox has failed if it's the same as the Td6 one |
Yes, the gearbox has a water to oil heat exchanger and if it leaks between the 2 circuits you will get coolant in the transmission fluid. |
Common issue ? Not read about it before. |
There have been a few, especially if the coolant has been diluted with water. Not confined to LR either, Merc had quite a large problem with a batch of Valeo radiators which did the same thing. |
