Home > Maintenance & Mods (L322) > badly scored brake disc
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
Noticed whilst I was out earlier that I was getting a little bit of juddering whilst braking, got out and checked the discs, the front pair are perfect and the near side rear is scored for about a cm from the outer edge, however the offside rear is badly scored over the entire surface. Any ideas what would have caused such uneven wear? Also I'm assuming I'm going to need a set of rear discs and pads any idea of costs?
Post #300774 24th Dec 2014 3:37pm
Sounds like the pads are stuck in the caliper carrier and everything needs a good clean out with a file. The caliper carriers will need to come off and the corrosion filed off in the grooves where the pads sit. The calipers may also be sticking a bit, which is probable if you haven't had them changed.
Pads are fairly cheap as it is a common design, from about £30 for a decent set, discs are iro of £50 a side and the calipers can be has as exchange and refurb units for about £70 a side.
Plus labour. If you don't do it yourself. There is nothing that can't be fixed with a hammer😜😜
Post #300778 24th Dec 2014 4:15pm
Vorbis
Thanks, not a chance of me doing it myself wouldn't have a clue where to start. Doesn't sound too horrendous I assume labour would be in the region of a couple of hours to do both sides?
Post #300779 24th Dec 2014 4:21pm
Something like that, would shop around for the best prices on oem discs. LRdirect is good for oem parts so are af and Dan. For my latest rear calipers from a local motor factors and they are remanufactured trw calipers by brake engineering, so far so good. There is nothing that can't be fixed with a hammer😜😜
Post #300780 24th Dec 2014 4:26pm
It is very unusual to get juddering from rear discs, possible but not likely, so be prepared to change the front as well if it doesn't go away..... Pete
Post #300782 24th Dec 2014 4:41pm
Vorbis
Was mainly just juddering on inclines. The fronts both feel smooth. Will it be safe to drive for a few days, kinda need it at the mo and this couldn't be a worse time to get something done.
Post #300785 24th Dec 2014 6:47pm
Yes, it will be fine to drive, as long as it's only doing it whilst braking... Pete
Post #300812 25th Dec 2014 12:27am
Vorbis
Thanks for all the help. Merry Xmas Smile
Post #300821 25th Dec 2014 7:41am
Vorbis
So all sorted for the princely sum of £350 including vat.
Post #301969 30th Dec 2014 9:56pm
