Home > Technical (L322) > fuel burning heater.
krisleeds
Strange but does anyone have any idea why the fbh should come on after moving my car a distance of approx 15 meters. Car was warm as I had just been out in it. Its happend before once where I had done same thing, but only moved it from the road to my drive and after locking car i noticed the smell of burning fuel and the heater was on. Turned ignition on and off again and it stopped. Car is 2007 vogue se tdv8
Post #301638 29th Dec 2014 3:03pm
Autobiography
2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
The FBH comes on to assist when the outside temperature is low when you start the car. The FBH has a set amount of time it can run before it switches off from what I understand. I too have the issue where it stays on when moving the vehicle from the drive to the garage for example.
Post #301648 29th Dec 2014 4:12pm
ebajema
What could be happening is that the programming lets it run for a bit of time to ensure that it doesn't foul up from quick start stop type action. MY 2010 5.0 SC Galway green and sand interior!!
Post #301652 29th Dec 2014 4:44pm
krisleeds
I thought it might have been something like that. Wonder how long it runs for. Ive switched it off for fear of fire lol
Post #301660 29th Dec 2014 5:19pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
As previously said, all is fine.
As soon as you start the car the FBH dosing pump activates and sends a small amount of fuel to the heater to assist with the engine warm up in cold temperatures.
Even if you switch off the ignition, the FBH needs to complete its cycle and will run for a few minutes until the dosed fuel is used.
Post #301672 29th Dec 2014 6:44pm
