Home > My Range Rover > New car
The 3.6 alternators are denso units so are Japanese....... And still Censored There is nothing that can't be fixed with a hammer😜😜
Post #286647 15th Oct 2014 5:14pm
Michael27
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Fuji White
At last I am home and have finally seen and driven the car. It is fantastic and just oozes quality but the deployable side steps have a mind of their own. When I lock it up and walk away the drivers side retracts about half way and then extends out again. Also the passenger side will only deploy about half way out when the door is opened. Is there a "reset" procedure of any kind to get them to work properly?
Post #301606 29th Dec 2014 1:06pm
ebajema
I'd suggest to first pressure wash the hinges and then let rip with WD-40. Pretty sure the mechanism is a bit rusty causing it to have too much resistance. Beter would be to either use a good grease (Shell Rhodina II is my fav) on all the hinges/sliding points or try a motorbike chain grease spray can. That stuff is incredibly durable. The best is the Wurth dry chain lube as it dries up and sticks really well for a long time. MY 2010 5.0 SC Galway green and sand interior!!
Post #301610 29th Dec 2014 1:10pm
Michael27
Brilliant, thanks I'll give it a go
Post #301611 29th Dec 2014 1:12pm
verydisco
Great tip about asking for coverage under warranty, i did not even think about it, just called and they will only need to see it to confirm, but should be covered, ditto with none waterproof side repeater Wink Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #301623 29th Dec 2014 1:56pm
verydisco
Just got back from LR dealer where I picked up some badges and indeed, they will replace the rubber strips and side repeater as a courtesy - they might not even claim it under warranty I think!
Part manager was shocked how they looked - about the same as yours
Worth asking then Wink Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #301644 29th Dec 2014 3:49pm
55palfers
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Santorini Black
I get that too!
I'll try the Wurth lube - thank you
Post #301649 29th Dec 2014 4:18pm
