Home > Technical (L322) > Heating vents not working in Auto |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6723 |
Is your car a Vogue SE? If so, you can make the rears work independently to the fronts by pushing the bottom right button. This allows for the read controls to operate, whereas, if this button is off, they are controlled by the main heating controls.
26th Dec 2014 6:50pm |
Lad Member Since: 11 Oct 2014 Location: Blackburn Posts: 284 |
Fan my brow was just about to search and then complain about my heater. Mine is on auto, with two little lights on the middle fan control speed knob. But no matter what the side dials are at (16-2 no waft from the fans. Like you Neil my D3 was fine, whatever the temp was set at it sorted it out perfectly. If I put defrost on I get the full fans and heated screens on as well, and if I turn off heated screens the fans still blow up screen. Putting max a/c on blows cold air no matter what temp is selected and whilst driving tonight started to steam up front screen.
26th Dec 2014 7:35pm |
neilw Member Since: 20 Aug 2014 Location: Devon Posts: 39 |
Looks like there were 2 of us sitting on Driveways tonight.
26th Dec 2014 8:13pm |
yes. Whilst our neighbours sat by their warm fires, we were trying to extract warmth from our cars |
27th Dec 2014 12:12am |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 |
I have the same issue with mine. It only gets warmer with the temp turned on max if on Auto. If auto is off, ( and just the horizontal line is on) it will blow air at around 23ish+. The dealer will be having look at the car on the 7th so will report back with what they have " found" 2011 5.0SC Santorini Black
27th Dec 2014 1:17am |
Chillb Member Since: 25 Jul 2012 Location: Portsmouth Posts: 142 |
found the same problem with my parking sensors when I got my FFRR. Can the fronts be activated by a software change by the dealer to come on automatically. Funny also got problems with with central vents not blowing cold when on auto at say 22, not hot either if you change wheel. Dealer said possibly an actuator had stuck. I have an occasional blast as if it is trying to open. |
27th Dec 2014 8:35am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
De rigueur to reverse into a parking space .
27th Dec 2014 6:54pm |
PS A couple of other questions, can the Drivers Door Mirror be programmed to dip as it does on a D3 and also the rear wipe to come on one sweep if you engage reverse when the main wipers are on.
28th Dec 2014 2:19pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35272 |
no and no.... ... - .- -.
28th Dec 2014 3:03pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
Mine does both of these...do only the 10MY+ vehicles have these features? |
29th Dec 2014 4:31am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3739 |
Yes 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
29th Dec 2014 8:37am |
I can't imagine the L322 not having the reverse dip mirror function of any age. The early ones were heavily based on BMW tech and they have had this function for as long as I remember... |
29th Dec 2014 2:10pm |
I know it's an old thread but I've come up with an idea why mine heater may not be working correctly
21st Sep 2015 10:05pm |
I will try and get the exact details but this is kind of the "problem" that the service dept found on mine. something to do with an internal thermometer reading. The way they identified the issue was by driving the car with a thermometer which provide the difference between the "actual" temperature in the car was and what the car thought the temperature was before enabling the heating. 2011 5.0SC Santorini Black
21st Sep 2015 11:26pm |
