Home > In Car Electronics (L322) > MPEG4 tv tuner for MY09 L322?
Eirik34
Norway
Hi, anyone that have installed the "M44HD DVB-T MPEG-4 TV Tuner" from Eldi in Bulgary?
http://www.eldibg.com/en/products/905-DAS+...otion.html
They claim that this will work on a 04-09 L322, but will it also work on the rear headrest screens (rear seat entertainment)? Anyone that knows?[/url]
Post #300926 26th Dec 2014 11:28am
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Doesn't the 2009 MY already have digital TV..? Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #301074 27th Dec 2014 12:23pm
it does but its in mpeg2 .. ... - .- -.
Post #301076 27th Dec 2014 12:29pm
comports
Embarassed Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #301088 27th Dec 2014 2:49pm
Eirik34
Norway
I've sent an email to Eldi to get some more information about this L322-compatible Mpeg4 tuner. Will revert with more information after I've heard from them.
Post #301138 27th Dec 2014 5:56pm
Eirik34
Norway
I've got a reply on this from Eldigb:
Quote:
Dear Sir,
I offer you this video interface: + DVB-T Tuner
Video Interface:
multimedia-interface for the connection of one AV-source to the factory-navigation. With remote function for connected devices, rear-view camera input, video-in-motion and trigger signals.
Land Rover touch-screen navigation version 1
The multimedia interface allows to connect one AV-source (after-market devices e.g. DVD player, DVB-T tuner) to the factory navigation system of the vehicle manufacturer. Very simple connection to the vehicle with the "Plug & Play" harness. If the AV-source is in the list of compatible devices, it is possible to control the AV-source by the factory infotainment. Additionally the connection of a rear-view camera is possible. Video-in-motion is included.
Product features
Full plug and play multimedia interface
1 AV-input with separate IR-control channels
Controls of after-market devices (e.g. DVD-player, DVD-changer, ...) by factory infotainment
After-market rear-view camera input (optional adapter AS20 is necessary)
Automatic switching to rear-view camera input (only from video interface mode)
Rear-view camera power (+12V max. 1A)
Power-on remote-out trigger-signal (+12V max 1A) to switch on connected devices
Video-in-motion
Compatibility
Compatible with Land Rover vehicles with touch-screen navigation version 1.
Used inter alia in the following vehicles:
Range Rover (Vogue) L322 (model years 2005-2009)
Range Rover Sport L320 (model years 2005-2009)
Discovery 3 L319 (model years 2004-2009)
Limitations
Factory TV tuner Must NOT be installed. If uninstalled, optical ring must be closed.
After-market rear-view camera Automatic switching to camera only from video interface mode. Optionally available adapter.
Specifications (Interface-box)
Operation voltage 10.5 - 14.8V
Stand-by power drain <1mA
Operation power drain 180mA
Power consumption 2.5W
Temperature range -30°C to +80°C
Weight 95g
Measurements
106 x 30 x 71 mm (W x H x D)
DVB-T Tuner:
DVB-T HD-Receiver with USB-Recorder (MPEG4)
Small housing dual DVB-T tuner with best reception performance and automatic frequency switching (AFS*). MPEG2 and MPEG4 DVB-T video compatible. With integrated USB port for playback of audio and video files.
*AFS - Auto Frequency Switching is a smart feature that allows the user to watch a channel when moving between 2 cities/areas where the channel is broadcasted in different frequencies. For example, channel "ABC" in city A is broadcasted on frequency 474MHz. In city B, this channel "ABC" is broadcasted on frequency 490MHz. After having scanned in each region once, when moving from city A to city B or vice versa, user can keep watching the channel "ABC" without performing auto search to find the new frequency in city B. When AFS is activated while scanning, the tuner recognizes equals channel names. Each channel is only saved on one program place. All frequencies a channel has been found on are saved in an invisible database.
Video/Audio output
- 1 Video output RCA
- 1 Audio output Stereo RCA
- System: PAL / NTSC
- Format: 4:3 / 16:9
- Video solution: 720 x 576 PAL / 720 x 480 NTSC
Receiver section
- 2 antenna inputs female Fakra
- 5V Phantom feed for active antennas
- Quick-Scan
Features
- USB port 2.0 for music + films + pictures
- Audio format: mp3, WAV, AAC
- Video format: MPEG-I/II/IV, VOB, AVI, DivX, Xvid, MKV, TS, MOV, RMVB
- Picture format: JPEG, BMP, GIF, PNG, TIFF
- Recording function of TV and radio
- Recording format: *.TSV (TV recording), *.TSA (Radio recording)
- Conax extension port for optionally DVBTC-CONAX (Pay-TV)
- OSD language: German, English, French, Portuguese, Spanish, Italian, Dutch, Finish and many more
- Auto Channel Search
- EPG - Electronic program guide
- AFS - Auto frequency switching
- Teletext
- Subtitel
- Subtitel format: SRT, SUB, SSA, ASS, SMI, PSB, TXT, IDX
Accesory
- IR-sensor
- IR remote control
- Power connection
- Manual
- Bracket and screws for attachment
Power
- Input voltage: 12-24 V DC
- Power consumption: 5,5 Watt max.
Dimension
- Dimension (W x H x L) : 135 mm x 25 mm x 80 mm
- Weight: 0,253kg
Controllable by our interfaces.
If you need and DAB Tuner we can add.( DAB/ DAB+ mobile AV radio-tuner.)
Regards!
ELDI Team
On my question to this info if the rear camera still will work, and if one can view TV on the headrest screens, the answer was:
Quote:
Hi,
it takes longer to get an complete information about interface compatibility from the manufacture for your case.
In the Range Rover 2009 L322 TDV8 with rear seat entertainment it is possible to install the
DT1-LR interface instead the OEM TV tuner.
Factory TV tuner must be uninstalled .
It is possible to view TV from the rear seats through the RSE screens.
Factory installed DVD changer still work and camera will work.
Regards!
That should mean that one can replace the factory installed hybrid TV tuner with this DT1-LR tuner, and then everything will work as it should do, or?
Anyone having experience with this equipment?[/code]
Post #330832 3rd Jun 2015 6:43pm
Why would you want MPEG4 compatibility as its really only needed for hd which the ff standard screens can't display? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #331304 6th Jun 2015 6:23pm
jambo27
I think Norway only transmits digital tv in mpeg4 whether its for the HD channel or corresponding SD channel but I could be wrong 2008 TDV8
Post #331364 7th Jun 2015 8:14am
Eirik34
Norway
Yes, you are right, Norway only use the Mpeg4 standard in the transmission.
Post #331445 7th Jun 2015 11:03pm
as said, norway [and ireland] use the mpeg4 system...
there isnt a LR tuner for the FF that provides this standard...the FF tuner standard is mpeg2 and uses the MOST fiber optic wiring.
if this 'new' tuner provides mpeg4 via MOST ,then it will be ok but i've not seen anything like this [yet] ... - .- -.
Post #331458 8th Jun 2015 6:24am
clemenz
Austria 2006 Range Rover Vogue Td6 Zermatt Silver
i had a look at these interfaces.
in my opinion they are not that plug and play as you wish.
you need to attach the video signal direct to the headunit via fakra
and also connect most!
is there any solution with most to get 1-2 av inputs where you only change the
tv tuner in the trunk?
is the original tuner also connected via most and fakra or just most?
so maybe one can use the old fakra cable to attach the interface?
best option would be av interface with two inputs, one for tv tuner the other just for audio use.
Post #334664 27th Jun 2015 11:32am
clemenz
ok found one myself Very Happy
this tuner has MPG2 and CI Interface AND two video inputs!
http://www.rgsound.it/das-m44ci-most-plus-...21518.html
There is also an HD Version with MP4, can't find a good source :/
have a look at the products at their site!
User Guide
http://www.dasdvbt.com/doc/digital_tv/M44-CI-CAN-en.pdf
i think the "only" problem is to get a fakra connection to the headunit!
here you can see specific installation for Range Rover, also MY09!
http://www.dasdvbt.com/ita/software.php
you choose the car and then you can see the downloads! there is an PPT with pictures
if you have a look in the user guide you see the interface on screen, ok its not pretty but it works Smile
EDIT:
M44HD seems discontinued Sad
http://www.eldibg.com/en/products/884-DVB-...T1-LR.html
dvbLogic2 has also MP4
Post #334669 27th Jun 2015 11:46am
Eirik34
Norway
Hi, interesting - I'm not that into the How-To part of this, so maybe a silly question from me: What is the FAKRA-connection to the headunit? And Why is that important?
I observe from the http://www.dasdvbt.com/software.php page that there is a difference in installing the system to a MY09 versus to a MY07. I first posted this thread in Dec 14 - we were at that time considering buying a FFRR MY09, but we ended up buying a FFRR MY07 - also having RSE. So I'm still eager to substitute the factory installed TV tuner with a new one that supports MPEG4, and that can be integrated with the existing audio/NAV-unit. But my main priority at the moment is to figure out the cause of the battery drainage in the car... ( http://www.fullfatrr.com/forum/topic32456.html )
Post #334979 29th Jun 2015 8:05am
clemenz
fakra is the typ of plug for the connection. you need a video connection from the tuner to the sceen in the front.
the most connection, as i understand, is only for audio and the controls. on the rear of the headunit you have three video ins (nav, tv, rear cam).
yes, as it seems gen1 navi hast the fakra connection and gen2 has other type.
but if there is a video connection to the tuner in the back, where is it?
maybe anyone can answer this question!
if the video is in the big connector for the tv maybe one can use this to make installation easier.
i dont want to take dash cover apart :/
Post #334995 29th Jun 2015 9:53am
