Home > Maintenance & Mods (L322) > Roof Rail Strips - one end won't stay down
scwilson
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Epsom Green
Merry Christmas to all!
I have a 2003 4.4 V8 Autobiography and I have noticed that on one of the rail strips that run along the roof from front to rear, one end is sticking up. I have tried to push it down but it keeps popping up, this is the end near the tailgate. Everything else on them is fine, including the little flip up ports that I presume you take out to fit bars etc.
Anyhow, would anyone recommend I glue this down? I tried a supermarket superglue but it just flips up so I need something more substantial/stronger I think. Not quite sure why it pops up at that end, nothing is stopping it from sitting down in the groove, it just looks warped a little.
Any thoughts/suggestions? Has anyone had this problem?
Post #300876 25th Dec 2014 5:10pm
whippetman
Fixed mine on the RRS with Rhino glue held down with tape whilst setting.Worked for me...
Post #300879 25th Dec 2014 5:25pm
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
Hi mate,
I spoke to dan (duckworths)
http://www.fullfatrr.com/forum/topic27172.html
The clips gone. Prise the strip up gently, unscrew the old clip off the peg.
Clip the new part into the strip ANC push it onto the peg.
Job done
Merry christmas
Jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #300881 25th Dec 2014 5:37pm
scwilson
I have prised it up but I can't see anything that looks like a clip. I can see a black threaded stalk about 1-2cm in height.
Post #300882 25th Dec 2014 5:51pm
scwilson
Can someone tell me how these clips fit on? I can see a black peg I guess but nothing attaches to that. My options are glue or source some new clips from somewhere but I have no idea how the clips fit on the rail strip.
Post #301013 26th Dec 2014 8:38pm
The clips have a hole in the middle that fits to that peg... The clip maybe still in the rail? If so, the peg part has broken... If not, it looks like it is simply missing...
My advise would be to either A, buy 2 or 3 clips to replace/repair the broken end or B, remove the strip (carefully) and replace all the clips... Just incase there are more clips broken further along Thumbs Up
Post #301014 26th Dec 2014 8:48pm
scwilson
Thanks for the advice. Can you point me in the direction of where I would buy said clips from? Smile
Post #301015 26th Dec 2014 8:52pm
Dan @ Duckworth's is a site sponsor
Click on the link below and either send him a PM or start a new thread sir Thumbs Up
http://www.fullfatrr.com/forum/duckworth-parts-vf24.html
Post #301017 26th Dec 2014 8:56pm
scwilson
Thank you. I have sent Dan a PM. What a great forum!
Post #301117 27th Dec 2014 3:54pm
Thumbs Up Bow down Thumbs Up
Post #301186 27th Dec 2014 8:14pm
scwilson
I received my clips so I lifted the rail some more and found I had two broken clips. So I fitted the 2 new clips onto the pegs. I only pushed them on but they would not push on all the way down without me breaking my fingers, was going to get a rubber hammer of some sort and hammer them down but though best of it in case they broke.
Looks like these new clips (the centre hole is different than what was originally on the vehicle), more of a triangular hole, I assume hand pushing these things on is OK or does it require to be hammered on?
The rail appears stuck in place now and better than it was although not quite flush (as in flat) but I am just being picky. I was going to remove the rail and hammer the clips down some more but I am worried of breaking them Smile
Post #302505 3rd Jan 2015 4:10pm
