Home > Technical (L322) > Heated Front Screen Operation
Page 3 of 3 <123
thanks robert Wink ,
havnt noticed the 'heat haze' but then i've not been looking,which i now will next time i use it Laughing ...... ... - .- -.
Post #299658 18th Dec 2014 12:35pm
ebajema
Geoff, what you can also do is put a little electric fan heater in the car, extension cord into the house and plug it in in the morning. I used to do that on cold winters in my Triumph Herald and it worked like a dream. A warm interior and clean car and since the engine and heater started working relatively quickly it didn't get too cold after driving off.
The Swedish do something similar only then they usually add a heating element in the cooling system of the car with an external plug. It is great as that also heats up the engine coolant making the engine start "warm" and allow the heater to work straight away as well. MY 2010 5.0 SC Galway green and sand interior!!
Post #299660 18th Dec 2014 12:42pm
Scottyav
United Kingdom 2007 Range Rover Autobiography TDV8 Zambezi Silver
I put a small fan heater in the TT cabriolet as its always dampish ages ago and that helped as it stands abit Thumbs Up _____________________________________________________
Zambezi silver Vogue Se unique Smile
Post #299665 18th Dec 2014 1:25pm
Robert wrote:
When I switched on the screen heating (not often needed) I noticed a slight trembling (as one would see above hot tarmac in the distance) that would disappear immediately when switched off . Anyone noticed that? Is that normal? I find that irritating.
Nicely done Stan, snow in the desert Thumbs Up
Robert,
NKSC had this on his 2nd windscreen replacement. It took them 3 goes. The screen made you feel dizzy. He had it replaced. Discovery 4 HSE
Post #299692 18th Dec 2014 4:52pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Pleased for RRUK sounds like problem solved.
As for the Fuse location:
I started a thread on screen fuse location for 2010 a couple of weeks ago.
http://www.fullfatrr.com/forum/topic28930.html
If anyone knows then it would be a great help.
Not got round to looking at Topix - hope to over xmas break. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #299706 18th Dec 2014 6:23pm
Page 3 of 3 <123
