Home > Technical (L322) > OBD - Anyone?
dantheman
OBD - Anyone?
Hi guys,
Been thinking about trying to buy an OBD tool/reader for my wagon? Is there a system that'll work for most vehicle makes, just out of interest - or are we talking unique to LandRover???
Reluctant to fork out a fortune everytime a dealer plugs in... Any help/advice appreciated! Wink
TVM
Dan
Post #2988 16th Feb 2009 3:24pm
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Autologic is the tool of choice IMHO
Post #2989 16th Feb 2009 3:55pm
Larry
England 2006 Range Rover SE Td6 Java Black
The easiest (although not cheapest) option is to buy the RAC one (Argos sell it!). It reads the codes well enough and some basic engine data. It'll even reset the codes and fault light. I think the basic reader is £60 and the deluxe version is £130 (which will record data and interface with a PC). There are cheap ELM chip based readers that are basically an ODB lead and software for a laptop are arguably better and more flexible, but sections of the software display in Hungarian!!!! There are some on e-bay from China that are dirt cheap.
The problem is that the ODBII standard only covers engines and then only the main codes. Manufacturers always have their own codes on top of that for vehicle specific kit and functions, which although can be read, will not have a descriptions associated with them on cheaper (DIY) readers. You can subscribe to websites to find out the descriptions, but are usually limited to searching for a couple of codes per day/week/month before you have to start paying.
The other problem is that these readers rarely cover airbags, AV, ABS, Alarm, Cruise Control, Transmissions (depends on manufacturers), chassis/drivetrain, suspension etc etc. Which probably account for a large percentage of the reasons you'd go to the Stealer to have the code read.
You also can't do the really useful stuff like change options in the software or programme new keys, remap etc. Then you're into a whole higher price bracket. I've not done too much research into that sort of kit - Autologic?? - but I reckon the min. price is £800-900, up to whatever you'd pay. If these are the things you want to do, I'd suggest finding a decent Independent that'll charge less than Landrover.
Or invest in the high end kit and I'm sure those on these forums would pay you a discounted rate rather than go to dealers. I know of someone who did that on another marques forum and made his money back and a stack more by just undercutting the main dealers by 50% (and doing the things that Dealers don't like doing such as enabling modifications etc.)
Post #2990 16th Feb 2009 4:11pm
speedymarktd6
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
i agree with the above also try the snap on readers on ebay onto no6 Range Rover
Everyone needs a hobby
Post #2991 16th Feb 2009 5:36pm
Wagon??????????? Censored Discovery 4 HSE
Post #3027 20th Feb 2009 3:50pm
dantheman
lol! Oops - slip of the tongue, purely occupational... Whistle
Cheers for the advice guys, you're right! Not cheap at all for the full ish at all... I'll keep my ear to the ground on this one.
Post #3031 21st Feb 2009 12:11pm
ken
Good Indi's use AutoLogic promise
Post #3033 21st Feb 2009 4:46pm
jope
Norway 2003 Range Rover HSE Td6 Java Black
I do have the diagnostic tool from blackbox solutions. can read/clear fault, monitor values, change settings.
Excellent tool/diagnostic
Post #4752 8th Apr 2009 11:43pm
dan_uk_1984
If you only want to read and clear stored faults then you can do this easily and cheaply with a USB OBD Scanner for a laptop (under £20)
Mine has been invaluable in tracking down reasons behind the Check Engine Light and for confirming that issues have gone after fixing/replacing things.
Their diagnostic ability is somewhat limited, however one useful tool is that it can query available sensors, to see the Lambda output in a graph can show you if something untoward is happening.
Post #4760 9th Apr 2009 10:27am
Marmine
Finland
Any updates on this subject?
Post #257146 1st May 2014 7:20am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Lazarus thread - previous last post 2009 Shocked
Search ID Tool and you'll find the info you need. A basic ODB reader wont be much use on a Range Rover 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #257151 1st May 2014 7:47am
the only diagnostic tool worth having for the FF is the iidtool by GAP..do a search for more info.. ... - .- -.
Post #257152 1st May 2014 7:49am
Marmine
Finland
Thanks mate 300-400£, sounds like a deal if it's the quality product.
Post #257155 1st May 2014 7:57am
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
[img]http://www.fullfatrr.com/gallery/albums/userpics/14187/Hawkeye_manual.pdf[/img]
i have had the hawkeye diagnostic tool for a number of years now and it has been very good for reading and clearing faults, used it many times when i first got the car(FBH issues,airbag light,engine check light ect ect)even tells me about faults i did not realize it had.
a self contained unit with a good read out
small enough to keep it in the car at all times(just in case the dreaded bong sounds and a warning lamp appears)
fool proof to use,live vehicle readings as well as fault reading and clearing
not VIN locked
it just does not go deep enough for me .cant change any settings on the car with it
but if all you want is to read and clear faults on any of the systems and do the occasional health check i would recommend it
i have use of a T4 at a friends workshop but i still bought this tool because in the 30 mins it takes me to drive to the workshop i have usually diagnosed the fault,cleared it and back in the house cracking open a stella to celebrate its nothing wallet breaking
Post #257164 1st May 2014 8:39am
RR2008HSE
IID definitely recommended. Thumbs Up It does what it says in the tin and the customer support is first rate.
Post #257317 2nd May 2014 12:46am
