![]() | Home > Maintenance & Mods (L322) > 4 wheel alignment oddity |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
My SC has always run straight as a die on all roads, you can let go of the steering wheel and it just sits straight.
My wife doesn't know which is L or R either |
It should naturally drift left due to the camber on most roads, but agree with you it is odd that the garage had it figured as drifting right - this might have been why it was going dead straight - could have been even more right b efore you hit the potholes etc?
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 ![]() ![]() |
What about swapping front wheels around. I'm thinking it could be a softer tyre wall? Previously..
Tyres are all same age, mileage and wearing evenly. Not been rotated. Discovery 4 HSE
An Update:
Picture to illustrate the tilt of the wheel when driving in a straight line. Tried editing this but for some reason the upload tilts the damned photo no matter which way I save it on my phone. Sorry
Your explanation about your photo has spoiled my
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Maybe, you have a worn steering joint. Maybe a track rod end? Instead of concentrating on the alignment, perhaps have a check of the front suspension joints. If you jack car on one side an inch above the ground, then force in a crowbar end and get someone to rattle it up down hard, you might see some clunking - and you can side to side clunk the wheels a bit to check against the top to bottom play etc....
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Yep - you don't need to have OCD to get p |
It's a slippery slope I never managed to get mine straight a major hate of mine too. I found myself looking at other cars as I passed to see what position their steering wheel was in relation to mine |
Adam. Are you putting it in tight tolerance mode when it's being aligned? Makes a massive difference.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Adam, that wheel is not right at all, much further out and the steering angle sensor might throw an error or two.
