![]() | Home > Technical (L322) > ENGINE STUTTER 2005 TD6 |
When did you last change the fuel filter? |
Agreed... Filter or pump? |
If the rev are increasing but the car is slowing its not the engine is it ? I would lubricate you gear linkage first it could be simply slipping out of gear , very common for the linkage to get a but gummed up and stop it engaging cleanly and a simple job to do . 2008 MY Supercharged
jinx1959 Member Since: 08 Aug 2014 Location: North Ayrshire Posts: 16 ![]() ![]() ![]() |
Hi guys the fuel filter was only changed 2000miles ago. |
Paul_H Member Since: 17 Dec 2013 Location: Bracknell Berks Posts: 126 ![]() ![]() ![]() |
Just had this on mine, it was the low pressure fuel pump, it has been replaced with a genuine LR one and all is well again |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Agree on the fuel pump too but also check turbo inter cooler hoses, as the extra boost from booting the throttle could force open a hole which is not open at lower boost levels, reducing performance significantly. There is nothing that can't be fixed with a hammer😜😜
Thanks to everyone for the advice. I changed the low pressure fuel pump and changed the fuel filter. Car is now running ok. |
