![]() | Home > Maintenance & Mods (L322) > Fuel leak |
The fuel pump is on the near side in front of the rear wheel underneath a bolt on flap
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Apparently it's part of the FBH setup, was totally corroded and shot but had the number 89372A on it which is webasto 12v dosing pump, pulled the pipes off either end and joined it together with nylon pipe taped the electric plug up and runs fine no bongs on dash or fault codes no FBH smell anymore or motor noise 👍👍 not as if it's siberia so will get round to do it maybe one day but the cabin gets hot inside really fast anyway so not bothered or concerned tbh |
I really do not understand why they put it there, should be in that protected cubby with the secondary pump. Actually, might do a mod to put it in there |
birchyman71 Member Since: 18 Feb 2013 Location: stockton on tees Posts: 147 ![]() ![]() ![]() |
The pump for the fbh gives a metered amount of fuel to the burner you shouldn't bypass it as it may be possible for the burner to carry on drawing fuel!! |
The fBH doesn't run at all now without the other plug connected which is fine |
