Home > General > How far do I need to drive?
drakes
United Kingdom 2010 Range Rover Vogue TDV8 Stornoway Grey
We all know short journeys kill the battery because you take so much out to start the car but how long do you need to drive before you have replaced what you took out of the battery. I know there are lots of factors involved like lights, heaters etc but anyone hazard a guess at some ball park figures. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
2005 4.4V8 (M62) Bonatti Grey/ Parchment interior - gone
1998 4.6HSE Blue/ Cream interior (can't remember exact colours) - gone
1977 White - gone (should have kept)
Post #298374 11th Dec 2014 3:12pm
RiccartonRR
If mine gets started it does a minimum of 13 miles (nearest civilisation) and neither this car, nor the D3 before, ever had low battery issues. Mind you, it'll do a 50 - 60 mile run at least once a fortnight so that may help Thumbs Up
So I guess my answer is - I don''t have a clue Rolling with laughter
Sorry!
Post #298381 11th Dec 2014 3:44pm
Bingo_123
there cant be a straight jacket formula. depends on multiple factors :
condition of battery
charging/discharging ratio
load on battery etc
but letting the car reach optimum temp and decent run every fortnight is gud. and batteries last 3-4 yrs so more chances of battery going kaput if its too old.
Post #298392 11th Dec 2014 4:32pm
NeinFondue
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Santorini Black
I keep mine on a CTEK MXS5 battery conditioner as I don't do many miles and these cars have a lot of toys sapping power even after the car is off..
Post #298402 11th Dec 2014 5:23pm
Chillb
United Kingdom 2008 Range Rover Vogue TDV8 Rimini Red
Was thinking the same too as I have started to use the remote heating most mornings for 5-10 mins and most of the time I only do 4-8 mileas a day however may do a 200 mile round trip every couple of weeks. Assume this also benifits the engine as it helps to get it to operating temp sooner.
Post #298406 11th Dec 2014 5:51pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
the FBH works on heating the int if you use timed climate, unless it is <20deg C then it prioritises engine with some cabin heat.
Having said that it heats the coolant either way so has to help with engine warm up.
If its coldish (below 5deg? cant remember figure) FBH will come on when you start the engine anyway to help warm up process irrespective of timed climate.
Battery, when i was having battery issues and had to jump it the 8 mile school run had it charged enough to start again no problem. Cheers
James
Post #298410 11th Dec 2014 6:00pm
TheTowers
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I've always worked on 6 miles to recharge a cold start, but in reality, it's a length of string thing. Dont think it will be much less than that though.
Post #298605 12th Dec 2014 3:20pm
I'd like to say I worked this out for myself but I haven't got enough fingers....!!!
Quote from a physics website I found....
"If the car draws about 350 amps for 3 seconds to start. That works out to be 0.29 Amp-Hrs.
The alternator on a car can easily restore that amount of energy in 40 seconds at about 40% efficiency. Which means about 0.62 Amp-Hrs are needed from the alternator to recover the battery."
Don't know if the diesel is the same but the alternator on the early V8 doesn't put out anything for 30secs to aid starting so 1min 10secs and your battery is topped up again....
Sounds a bit quick to me, suppose it must be the FBH drawing loads of current on the diesel that gives battery problems, plus heated seats/wheel/windows etc..... Pete
Post #298620 12th Dec 2014 5:02pm
