Home > Maintenance & Mods (L322) > side steps removal |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35379 |
if you take off the steps [easy] then you'll be left with front flaps that have a 'cut out' in them where the end of the step went in...you can take these front flaps off but you'll have screw holes left and probably a dis-colouration line showing...you can replace the 'step' flaps with normal ones.. ... - .- -.
9th Dec 2014 12:28pm |
crispy2 Member Since: 18 Aug 2013 Location: Mandurah Posts: 102 |
Ok, thanks Stan, so if I take them off and ordera set of regular (non side-step flaps) then they will attach in the same screw holes as the removed flaps I hope.
9th Dec 2014 1:55pm |
you might find that the replacement flaps wont marry up on the holes...if you look at the powerfuluk video on the fitting of steps/flaps you'll see that the step/flaps have different holes to the normal flaps .....but it shouldnt matter as they will be hidden.. ... - .- -.
9th Dec 2014 2:08pm |
If you do want to go flapless the small plastic panel with the screw holes is cheap to replace. |
9th Dec 2014 3:47pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3752 |
The back bumper isn't though - and when you factor in the cost of paint its not cheap - the flaps and side runners look good IMHO - plus make it easier for youngsters and the mature passengers to get in
9th Dec 2014 10:07pm |
Rear flaps are normally attached inside the wheel arch no painted panel damage.
9th Dec 2014 10:35pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
If fitted correctly by main dealers/professionally, rear flaps should have the same M8 nut & bolt through the side of the flap setup as the fronts... Meaning, when removed you should have (if fitted properly) a hole left in the side of the rear bumper sir... |
9th Dec 2014 11:09pm |
I guessed you would be along... |
9th Dec 2014 11:17pm |
@ Craig - quite correct
9th Dec 2014 11:21pm |
Thanks for all the feedback there. I am still undecided about if I will remove them yet. With three youngsters, I haven't conducted a poll on their vote (with/without runners) and I am easy either way.
9th Dec 2014 11:25pm |
Your welcome sir |
9th Dec 2014 11:34pm |
