![]() | Home > In Car Electronics (L322) > Newbie with a couple of question (RR2002 Vogue) |
BenjaminD Member Since: 08 Dec 2014 Location: Brisbane Posts: 19 ![]() ![]() ![]() |
Hi all,
http://www.fullfatrr.com/forum/topic27033.html?highlight=android
The other solution is upgrading to a 2010+ model year |
Well since I just went through the hassle of buying a new car, and the 2010+ being well over my budget, not really an option. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8554 ![]() ![]() ![]() |
You could use the Android unit with a separate amp and crossovers, just treat it as a "normal" ICE upgrade, you end up with four outputs from the head unit and 10 pairs of speaker wires in the boot (running 11 speakers as the front middle one is piggybacked) and wiring for a sub, there is plenty of room to fit amps etc in the boot when all the original stuff has been removed and the unit does work well... steering wheel controls SatNav etc...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
Well the mk4 Nav will make it a bit more useful, offering a dvd based system and a 3d perspective mode.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Potential not much help as I can't remember exactly.......
Here you go -
Thanks for the quick reply guys.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Having looked at that unit, it is the same as the android, but it's not an android unit? So the install is the same, run a long cable to the boot and aerial back. I have seen it mentioned that the carrier frame on some models has to be adapted to make it fit. But basically the unit is the right shape.
Thanks for all the replies. I also read Haylands 17page thread and it was very useful but also raised some additional questions.
You have a mk3 sat Nav and a bm54. To use the proper dedicated aux in the firmware on the bm54 needs to be upgraded. This applies whatever head unit is in.
Thanks for that!!!!
Thinking on......
