Home > Technical (L322) > Temperature display
davidalanbatt
2003 Range Rover Vogue Td6 Zermatt Silver
Temperature display
Since I replaced the battery, the outside temperature display now reads fahrenheit instead of celsius. does anyone know how to set it back to celsius? My RR is a 2002 model with the standard radio (not satnav).
Thanks guys.
Post #16456 11th Apr 2010 9:11pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
thats easy and cheap Razz
go to the set up on your mid (Radio) and look through the menu and you will find you can change between the the two, if you get stuck get your car instruction book out and read
Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #16457 11th Apr 2010 9:29pm
davidalanbatt
Thanks Andy, I couldnt find the information in the radio handbook but I will have another look.
Post #16458 11th Apr 2010 9:33pm
andyw
just checked i cant do mine either sorry Embarassed
i am determined to find out watch th this space 02 Range Rover HSE Zambezie silver 4.4
Post #16459 11th Apr 2010 9:54pm
davidalanbatt
Has anyone any more ideas on this one?
Thanks guys
Post #16838 18th Apr 2010 8:32pm
jayzee
2006 Range Rover Vogue SE Supercharged Java Black
http://www.justanswer.com/questions/3c9vk-...to-cels-rr
Not a complete answer on there, but nobody has said if the last fix worked. Got to be worth a shot?
Or try ignition in position II; press and hold the trip reset button for 2 secs? Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD!
Post #16943 19th Apr 2010 7:32pm
andyw
right i did say watch this space and i have gone through rave and this is what it said
Ambient Temperature
The external ambient air temperature is measured by a sensor located behind the Land Rover badge on the front grill
and is connected directly to the instrument pack.
The ambient temperature sensor is an NTC sensor whose resistance falls as the ambient temperature increases. The
instrument pack outputs a reference current of 5.1V to the sensor. The instrument pack microprocessor evaluates the
returned signal and converts the information into a temperature value and displays the appropriate temperature in the
LCD. The temperature display can be adjusted by TestBook/T4 to be displayed in either Celsius or Fahrenheit,
dependent on market requirements.
The instrument pack continuously transmits the ambient temperature signals on the CAN for use by other systems,
when the ignition is on. When the ignition is off, the instrument pack transmits an ambient temperature message on
the I/K bus, once every 10 minutes, for a duration of 400ms.
hope this sorts the answer you must have reset it on the change of battery
Whistle 02 Range Rover HSE Zambezie silver 4.4
Post #17041 20th Apr 2010 6:43pm
davidalanbatt
Thanks for your help guys. It looks like a trip to the dealers then! Sad
Post #17256 22nd Apr 2010 9:38pm
Fox
That's a bit daft isn't it?
Some people in this country use C and some use F.
In most cars you just push a couple of buttons at the same time on the heater controls and it changes it over.
Post #17266 23rd Apr 2010 8:02am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
I might be wrong....but surely it IS a setting, because you can change the RANGE/LANGUAGE to KM's ... and I'm sure that when you do that, the temp goes to F (It has been a long time since I owned a 4.4 tho....)
Having read the handbook on GTR it seems odd that the function is not mentioned Yawn Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #17268 23rd Apr 2010 8:12am
andyw
you would have thought but i spent 20mins sat with the hand book and sat in the car but no joy so i searched the rave and thats what it said Neutral 02 Range Rover HSE Zambezie silver 4.4
Post #17328 23rd Apr 2010 6:34pm
DMRR
I wonder if it works like the Disco II setting then?
Quote:
If your temperature reads in climate control reads in degrees Celsius “C” instead of Fahrenheit “F”, follow these steps to change to Fahrenheit.
* Turn the ignition on.
* With the climate control turned on, push and hold the recirculation button in. While holding the button in, push and hold the off button in for 3 seconds or until you hear a beep.
The display should then change to “F”. Follow these same steps to change your read-out to Celsius , if preferred.
Worth a try to see if there is some combo on the FFRR too Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #17344 23rd Apr 2010 8:26pm
davidalanbatt
Thanks Thrasher, I tried this but my model does not seem to have an off button for the climate control.
Post #17412 25th Apr 2010 7:50pm
andyw
did any one get this changed back to deg c and i have done the same bloody idle hands 02 Range Rover HSE Zambezie silver 4.4
Post #29755 28th Sep 2010 7:18pm
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Ok try this, bearing in mind it is 6 years since I owned a TD6SE without fancy computers or satnav!) on the LH stalk on the steering column (the silvery tipped one with the "i" carved in it that changes stuff in the driver info screen in the dash), press it in and hold it so it scrolls through the functions to UNITS and IIRC you will find the miles per litre and temperature units change choice. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #29757 28th Sep 2010 7:36pm
