Home > Technical (L322) > Routine operation of the transfer 'box |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35253 |
when i had my navara d40 , i was told to use it once a month as well. ... - .- -.
28th Sep 2010 8:56am |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
I use mine every couple of days in traffic, to make sure it's all working properly. Including manual selection of gears in low range. |
28th Sep 2010 8:59am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3736 |
When used off road or tow a heavy trailer, usually 3 or 4 times a week - especially in the winter |
28th Sep 2010 9:44am |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
The 07 MY onwards cycles the box on every start...according to the technician that attended my car the other day...this is to counter this very problem.
28th Sep 2010 10:31am |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
A friends Range Rover classic was siezed in high, through lack of use. Would not budge! |
28th Sep 2010 11:10am |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
Every couple of weeks I put mine in low range just to check it works. 2006 Mercedes CLS
28th Sep 2010 2:49pm |
bit shocked at the poll results, do 37% of us actually check our oil and tyre pressures every week??
28th Sep 2010 3:04pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
You can drive as far as you want at up to 65mph in low box, it has no bearing on the centre diff operation..... Land Rover Addict
28th Sep 2010 3:29pm |
davemfox Member Since: 31 Jul 2010 Location: Chester Posts: 43 |
What he said Dave 1993 YZF 750 SP |
28th Sep 2010 4:44pm |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 |
mmmm when i get board and siting in the car i start to play with buttons and knobs and usualy the hill desent and low ration come to play.
28th Sep 2010 4:53pm |
cookie42 Member Since: 09 Oct 2008 Location: preston Posts: 46 |
never use it , mainly because the bloody thing didnt work when i bought the car |
28th Sep 2010 5:54pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
I check it every week, in the hope it will start working properly. I can switch to low ratio, but it won't switch back up to high. Have to turn off ignition, start up again and fiddle with the switch, then maybe repeat to get back to high. Someday....
28th Sep 2010 9:20pm |
Low ratio is just what it implies, in standard drive, ie no terrain response picked, just likely any Land Rover since the Range Rover classic and the Stage One V8 with permanent four wheel drive - low box is just lower gearing. In the series vehicles prior to the Stage One and early 110's there was a lever to operate low box, which locked the centre diff, making sure you had to drive off road. Discovery had a manual centre diff etc, but all modern can speed in low box as it is not related to the centre diff operation. Modern lesser crap locks the centre diff....(read not LR) Land Rover Addict
28th Sep 2010 9:53pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
In modern Land Rovers there isn't any manual difflock at all, the job that it used to do is now done by the viscous coupling which detects slippage and the fluid becomes more viscous between the plates in the coupling and in effect become solid. Even if you are fortunate to have an e-diff on the rear axle (standard on S/C 5ltr IIRC) you cannot manually control it, it also automatically engages. I was most impressed to see how well an RRS with the optional e-diff performed last weekend offroading in the Argyll Forest, and made a Dakar Challenge Mitsubishi Evolution look stupid when it came to traction in slippery conditions as the Evo has to have 5-6 wheel rotations to detect that it needed it's auto hubs to lock up, the LR system detected slip[page instantly and engaged the e-diff far quicker. One advantage of the system currently installed in all modern Land and Range Rovers EXCEPT Defender (which still has the manual diff lock referred to by Thrasher) and also X series BMWs, is that the viscous coupling cannot permit transmission wind up whereas in Defender driving on dry, metalled roads with the diff lock engaged in either high or low ratio you will do severe damage to the transmission due to wind up. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
28th Sep 2010 10:16pm |
