Home > Technical (L322) > Long brake pedal |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6409 |
Doesn't sound right. Take it back. .
5th Dec 2014 8:23am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35331 |
brakes need bleeding again. ... - .- -.
5th Dec 2014 8:56am |
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 |
Yep - what a pain and very disconcerting the dealer doesn't road test or check this sort of thing prior to returning the car.
5th Dec 2014 9:10am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Not 100% sure but I think the ABS block has to be purged with test book or similar when you change the brake fluid . 2008 MY Supercharged
5th Dec 2014 9:53am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Can i suggest you DONT return the car to the dealer. Rather ring the dealer and insist the car is collected on a recovery truck... As I'm sure i do not need to explain the safety implications of driving your car with either air in the brakes or worse still, a leak! (sometimes a leak means air gets in rather than fluid leaks out)
5th Dec 2014 10:18am |
Thank you for sharing your concern, I will call dealer now!! |
5th Dec 2014 10:21am |
by the way dont drive it , get them to low loader the FF, that'll teach them .. ... - .- -.
5th Dec 2014 10:25am |
Unfortunately I will have to drive it, they are only 6 miles or so from where I work, it was the 50 mile drive in this morning that was fun!! Need to get car sorted today and am sure that if I try to demand a trailer it will not be resolved till next week - i will take path of least resisitance (no pun intended!) |
5th Dec 2014 10:34am |
Just as an update, went back to garage and brake lines were bled, 45 mins, and now are back to normal.
5th Dec 2014 9:50pm |
glad its sorted now ... - .- -.
6th Dec 2014 8:26am |
Glad i wasn't driving around where you were sir |
6th Dec 2014 9:00am |
Usually do everything on all my cars myself. But then my background is very auto-centric: started as mechanic trainee at the age of 16 summers / after school and put myself through the university by turning spanners (all before becoming part of a rapidly growing diagnostic equipment co. ). And I am never satisfied with the work done on my cars by others.
6th Dec 2014 11:32am |
