![]() | Home > Maintenance & Mods (L322) > First signs of cold weather and.., |
Flunter Member Since: 27 Apr 2014 Location: East Yorkshire Posts: 26 ![]() ![]() ![]() |
Thanks chaps. |
Can anyone tell me if it's the correct pump? |
B9er Member Since: 10 Dec 2012 Location: Larne Posts: 191 ![]() ![]() ![]() |
From the pictures, it looks correct. This is the inline pump located in front of the passenger side rear wheel and under a little plastic cover.
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Just an update of my experience recently. I've had the message come up as +3 degrees, but have found no loss in power, so sorry I can't help, hope you get it sorted and please post your findings.
Thank you. No, the car has not been connected to an OBD2 code reader, at least not since last September. I tend to agree with you about the pump not being the most likely cause. I'm not particularly mechanically minded but I find it strange that if it was the pump why would it be temperature related? The car starts and revs with no issues, after around 90 seconds to 2 minutes it refuses to rev. I then have to sit on tickover for around 15 minutes until the car is up to temperature, then I can drive away normally. I'll check out the connections over the coming weekend, thank you for the suggestion. ![]() |
