Home > Technical (L322) > PCB for Fuel Burning Heater? |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I seem to recall reading its part of the FBH. |
4th Dec 2014 5:22pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8653 |
pretty sure its integral to the control unit/heat exchanger on the FBH, so you will need to get under the wheel arch. There is nothing that can't be fixed with a hammer😜😜
4th Dec 2014 5:29pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Yep I sent mine to France last year.
4th Dec 2014 5:38pm |
Steverr Member Since: 27 Oct 2013 Location: Bristol Posts: 191 |
Yep fbh is behind the left front wheel, below the battery. The PCB is on top of the fbh heater, but has to come out to get it !!! |
4th Dec 2014 9:05pm |
J evro Member Since: 31 Aug 2014 Location: Kent Posts: 541 |
Thanks Chaps,
5th Dec 2014 2:16am |
Yep. Need to patch the flow and return lines together then top up coolant. Squeeze off the hoses before you remove it to reduce the coolant loss. There is nothing that can't be fixed with a hammer😜😜
6th Dec 2014 8:35am |
Thanks for the tips chaps ,
6th Dec 2014 5:37pm |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 |
i am sure somebody on here said that the pcb can be removed from the top without removing the whole fbh |
7th Dec 2014 9:29am |
Yes me too,
7th Dec 2014 11:59am |
