Home > Technical (L322) > FSR- symptons of failure
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
Wondering if you guys can help.
i have read on hear about changing the FSR due to battery issues etc.
What i would like to know is what are the symptoms of the FSR failing or having failed? i believe it controls fan speed, high resistance to allow low fan speed, resistance reduced to allow fan to increase speed.
So if its on its way out does it still work to some degree or does it fail completely - ie no fan.
my 10MY 3.6 seems to have very little fan output at low speeds but i can feel in increase when i turn it up, but not as much 'wind' comes out as from previous models when on full fan speed setting. would this be consistent with the FSR degrading? Cheers
James
Post #296908 4th Dec 2014 8:42am
From what I know it either works or it doesn't.
Symptoms:
fans on all the time
or
no fans
and/or
battery drain
You should be able to test by turning fans up to full manually. If no fans then likely the FSR has run its course. .
Post #297071 4th Dec 2014 9:50pm
JST
thank you for reply.
i have fans, but they just seem much slower even on full than they should be/previous/other vehicles i have used. Cheers
James
Post #297072 4th Dec 2014 9:53pm
Tuts
Hi mate - my FSR failed about a month ago, I only noticed when the fans would only blow to about half strength (even though all the lights went on). I noticed as I used to able to hear and feel the fans 'roar' when it was on max and recirc but it went very feeble! Changing the FSR fixed it . Btw I didn't have a battery drain problem - it was purely a problem with fan speed 2003 Vogue 4.4 V8 Java Black
Post #297440 7th Dec 2014 10:25am
JST
thanks Tuts.
vehicles was new to me, but fans werent great. Just changed it and much better performance from them so it seems they do fail into other states rather than just no fans which was my previous understanding same as Joes Cheers
James
Post #297567 7th Dec 2014 9:14pm
Tuts
No problem mate, did you change it yourself? Pat on the back if you did! (It's a pain to change!) Thumbs Up Thumbs Up 2003 Vogue 4.4 V8 Java Black
Post #297569 7th Dec 2014 9:23pm
JST
yes i did, it was a pain. Cheers
James
Post #297584 7th Dec 2014 10:22pm
I'll add "poor/feeble" fans to my list of symptoms next time Thumbs Up .
Post #297596 7th Dec 2014 11:10pm
