Home > Technical (L322) > Diesel leak when running
Andy
Hi all
I'm assuming this is something to do with a fuel line as it only drips when the engine is running and is dripping from directlyy under the engine. I can't see anything obvious but I haven't removed the drip tray yet.
Anyone had similar and if so, what was it?
Post #296949 4th Dec 2014 12:16pm
Check the pipe from the fuel filter to the high pressure pump, mine had a leak where the pipe attaches to the pump due to someone making a hash of fitting the pipe properly
Post #296960 4th Dec 2014 1:03pm
Andy
Well I've spent an hour looking for this leak and eventually found it.
It was the rubber hose that runs from the fuel filter. Where it's attached to what I presume is a pump of some sort (next to the oil filter housing mounted on the block- can't really see it) it was loose. The jubilee clip had seen better days so I replaced it and the leak stopped.
Post #297000 4th Dec 2014 4:47pm
What I said Thumbs Up
Post #297009 4th Dec 2014 5:25pm
