Home > My Range Rover > Proper load lugger!! |
3528cc Member Since: 29 Oct 2014 Location: North East Posts: 301 |
That's a "Good load"....... |
2nd Dec 2014 9:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35368 |
nice 'country side' pic that.. ... - .- -.
2nd Dec 2014 9:56pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
Bet that is over the 3.5 tonne trailer weight
2nd Dec 2014 9:57pm |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Nah - it's only hay Ciirca 250kg per bale so only a couple of tonne load.
2nd Dec 2014 10:06pm |
I know what you mean - how these peeps manage that you see towing one of these wee Halfords type trailers behind the FFRR down the motorway? They can't see it, they can't feel it & by christ they can't reverse it |
2nd Dec 2014 10:08pm |
KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848 |
Proper working RR that. |
2nd Dec 2014 10:14pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
The smaller they are, the harder to reverse they are... I have owned a tri axle & twin axle 16ft ifor and our 7foot trailer at home is by far the hardest to reverse! |
2nd Dec 2014 10:24pm |
Mind you, the tri-axle is always ready to catch you out. If you reverse over a lump / bump / crest the turn rate varies massively depending on whether the weight is on the front or rear axle. Twins are nowhere near as bad but are still affected. |
2nd Dec 2014 10:30pm |
Yes my new one is a twin axle replacing my tri axle... I also got sick to death of the punctures in the 10" tyres... Don't know if its just luck (or lack of it) but the bigger wheel'd twin axle ifor's don't seem to have so many punctures... |
2nd Dec 2014 10:40pm |
I managed to reverse my old small trailer Craig. You don't know how to reverse properly? I almost never had to un-hitch it and push. ....honest. :oops: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
2nd Dec 2014 10:43pm |
Bulls t...
2nd Dec 2014 10:45pm |
I suspect it's similar to motorcycles. With the short distance between the axles one tyre will pick up a nail and the next wheel will run onto it before it has chance to drop back to the ground. |
2nd Dec 2014 10:46pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Very nice load If it dont work.......burn it!
3rd Dec 2014 12:46pm |
I think RiccartonRR has taken many massive loads. |
3rd Dec 2014 12:56pm |
