Home > General (L405) > Headlight Shudder |
Doodle Member Since: 02 Nov 2013 Location: Midlands Posts: 127 |
Since new the dipped beam has shuddered against the road surface on A and B roads in particular, were there are more uneven surfaces. (Both near and off-side equally in tandem).
9th Aug 2014 8:46am |
jettec Member Since: 16 Jul 2013 Location: Melbourne Posts: 229 |
Hi I too have the head light shudder when I drive over bumps on the road and off road it is very evident I have had a look at the lights I think it is down to the length of the bulb in the light it is quite long and I think it must flex when hitting bumps I think they are a Philips ds3 light bulb. I have not found a replacement for these lights with more light output at the moment, as it is not that hard to replace the bulbs just remove the tops off the air filters, then I could see if by changing the bulbs makes any difference to the shudder using a different light manufacturer . |
18th Aug 2014 6:59am |
Thanks both for the info.
18th Aug 2014 10:11am |
Hi again Doodle, the FF Range Rovers still have a bulb they are HID bulbs that are quite long in length and have a wire that runs up the outside of the bulb, the base of the bulb is is a square shape that houses the ignitor for the High Intensity gas discharge bulb and I still think it is the length of this bulb that shimmies on bumps . |
19th Aug 2014 1:30am |
Thanks, did not realise this. Good advice and will look into this with dealer.
19th Aug 2014 8:12am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
Are they adaptive?
19th Aug 2014 10:03am |
Yes they are adaptive.
19th Aug 2014 9:00pm |
I have just returned from a 6klm outback adventure in the car covering a lot of off road driving the head lights now shudder quite badly over even the tinniest bumps I will be taking the car in , and will keep you updated as to what they find. |
8th Oct 2014 8:47am |
Thanks, this will be of great interest. |
8th Oct 2014 2:45pm |
When it is misbehaving, then stop (if it is safe to do so). I found mine continued to "bounce" even though the car was obviously stationary. That's when I filmed it - it is hard for the dealer to argue that it is the self-levelling when you are stationary! |
8th Oct 2014 4:19pm |
Emperor, I tried this when you last posted, but being on country roads it's finding a safe stopping point by which time they stop bouncing). Really irritating.
8th Oct 2014 7:38pm |
Hi all just back from the service department, they have told me that my headlights were set to left hand drive position not right hand drive for Australia they said this was causing problem ! Well have driven at night now and headlights still shudder on bumps in road, So back we go again! |
24th Nov 2014 12:05am |
Hi jettec, I also did beam for left/right/left just in case there was a slow actuator and same as you, it made little difference other than it seemed to occur less often.
24th Nov 2014 9:33am |
[u][b]Update.
1st Dec 2014 8:52am |
