Home > Technical (L322) > Electrical thermostat circuit fault
Trossachsturbo
Scotland 2002 Range Rover Vogue 4.4 V8 Oslo Blue
V8 4.4 Lpg using IID non bt tool whilst idling got the above fault, vehicle appears great in all modes, no trans probs. is this possibly part of the LPG BRC install, or should I change thermostat asap or is there a way to check the electronics? I have done a search here, but any advice would be welcome
Post #295333 26th Nov 2014 6:59pm
ironhorse
United Kingdom 2003 Range Rover Vogue 4.4 V8 Giverny Green
get it warm and look at the live readings to see how hot its realy getting
it may have had the electric stat down to earth mod on it to help it run cooler as its on LPG
may be nothing to worry about
ill post the thread on it when i can find it
nige
Post #295347 26th Nov 2014 7:49pm
ironhorse
http://www.rangerovers.net/forum/6-range-r...ure-2.html
nige
Post #295351 26th Nov 2014 8:18pm
Could just be it's been unplugged, or there is a known fault that water leaks into the plug, then wicks it's way up the wires and into the engine ECU and rots the ECU out as well.... so check the wiring and plug, if it is fitted, it's directly below the air intake pipe where it goes into the manifold, much easier if you remove this pipe first.... Pete
Post #295357 26th Nov 2014 9:16pm
Trossachsturbo
Thanks will check live values, and physical plug condition, seems to be a lot of info to lower temp by modifying housing and changing thermostat
Post #295362 26th Nov 2014 9:48pm
Yep, it just runs so hot as standard, can't be good for an aging engine, also helps with all the plastic and rubber items under the bonnet...
Mine "seems" to run nicer at around 90deg instead of the 110 it used to run at...
See the last page on this thread, seems to be the easiest way to do it, you have to grind the old stat out, a dremel works well....
http://www.fullfatrr.com/forum/topic24082-150.html
I've now got that fault you mention all the time but it doesn't throw on the MIL and seems to have no effect on anything else... Pete
Post #295389 27th Nov 2014 8:27am
