Home > Technical (L322) > V8 Petrol FBH |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
This probably won't be much help but I have just had mine repaired at the stealers - the fault showed up as flame out the solution was new pump but more importantly one of the feed pipes from the pump was blocked. Don't think this helps you much as it sounds like you are getting plenty of fuel through.
26th Nov 2014 8:10am |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3144 |
There is loads of info on here. Search FBH and u will see the circuit board is a common fault but a guy in France does a very cost efficient fix |
26th Nov 2014 9:08am |
ironhorse Member Since: 13 Dec 2013 Location: birmingham Posts: 355 |
im sure its only the fuel pump delivery rate that is different between petrol and derv systems(seen it somewhere but may be wrong)
26th Nov 2014 9:44am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Rpbbo, I'm sorry but i know little about these systems sir... However, my immediate concern whilst reading your thread is this...
26th Nov 2014 10:24am |
Robbo63 Member Since: 03 Nov 2014 Location: Midlands Posts: 28 |
Thanks for the response.
26th Nov 2014 1:04pm |
yes the smell of petrol is quite UN-nerving at times but the pumps in these things are metered and put a tiny amount of fuel into the heater,if they dont ignite properly the fan blows the fuel vapor out ready for the next go.
26th Nov 2014 6:28pm |
Cheers Nige. Glad it won't do owt until I tell it. Off out now for a play. |
26th Nov 2014 7:20pm |
26th Nov 2014 7:44pm |
