Home > Maintenance & Mods (L322) > Did the "full air treatment" and... |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3233 |
Fitting the upgraded crankcase breather is perfectly straightforward. Remove the covers, unbolt the old and bolt on the new. John
18th Nov 2014 5:54pm |
andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 952 |
did you end up having an issue? |
25th Nov 2014 12:38pm |
J. C. Member Since: 29 Oct 2014 Location: Padova Posts: 38 |
Thermostat not working correctly. Car's being fixed right now. No other issues reported.
25th Nov 2014 1:38pm |
Quick update: couldn't stand the extra induction noise any more, therefore I bought a standard Bosch air filter and replaced the performance one.
5th Jan 2015 8:13am |
Boydonegood Member Since: 12 May 2014 Location: Essex Posts: 445 |
Hi all
5th Jan 2015 10:53am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8195 |
The noise being described from the turbo when you back off, and sometimes when the car changes gear is the turbo stalling. When you are driving the turbo is spinning at 200,000 revs or whatever it's speed is, when you back off or change gear the throttle is closed shut, the pressure created by the turbo has to go somewhere and the place it used to go, through the egr, is blocked. The pressure then goes backwards through the turbo and stops it dead.... This can have significant impact on the life of the turbo... if it is doing it all the time you need a blow off valve (dump valve) to release this pressure safely. If you fit one it has to be matched to the turbo size and speed, don't just use a generic one, get the correct one from a specialist... Pete
5th Jan 2015 1:43pm |
