Home > Maintenance & Mods (L322) > spark plug schedule on 2006 ajv8 ? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
105K or 9 yrs from memory... |
23rd Nov 2014 10:51pm |
markcaughey Member Since: 03 Nov 2014 Location: Glasgow Posts: 316 |
Thanks . Also how often should the diff oil and transfer box oil be changed ? |
24th Nov 2014 12:47am |
I change my own every 30K or 3 years Mark and check it 12 monthly... I think from memory the book says 80 or 90k... A tip would be to take the drain out slowly and let a small amount run into a white aerosol lid so you can inspect its colour/degradation and if its clean just check the fill level |
24th Nov 2014 12:57am |
p.s. the rear diffs on your model tend to condensate terribly which rusts the diff/driveshafts and creates great expense! |
24th Nov 2014 12:59am |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1753 |
Spark plugs are 105k/7years
24th Nov 2014 6:41am |
Thanks . |
24th Nov 2014 8:46am |
Im starting to feel like I'm being "stalked"
24th Nov 2014 9:15am |
is there a diy/guide on here for doing it ? or how much is it likely to cost from my indy ? |
24th Nov 2014 10:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
dont know about a guide for stalking but have a look in the wiki for the gearbox stuff etc.. ... - .- -.
24th Nov 2014 10:36am |
found a guide for the transfer box oil change, looks easy enough. i noticed its on a td6 though will that be the same as the 2006 ajv8 ? can't find any guides on changing the diff oil but I'm thinking its much the same ? drain bolt and fill bolt etc |
24th Nov 2014 10:54am |
found this using the search function. its for a td6 but i'm sure its the same for yours..
24th Nov 2014 11:00am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8512 |
One thing to note is that the diffs are a specific quantity of oil, not a fill it till it runs out job. At least it is on mine...... There is nothing that can't be fixed with a hammer😜😜
24th Nov 2014 5:16pm |
25th Nov 2014 12:17am |
