![]() | Home > Technical (L322) > Where will I find the Lighting Control Module |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6419 ![]() ![]() |
Should be in behind the bonnet release by the accelerator pedal (RHD) or thereabouts .
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
As above... Remove the metal trim panel covering your sill, then the bonnet pull surround will slide out (pulling the bonnet pull up as it slides out) then you will need to remove the three torx bolts holding the bonnet pull lever to the bodywork and move to one side... The LCM is just behind (black box 3 x the size of a fag packet) held in with one bolt at the bottom sir |
kiter Member Since: 04 Jan 2013 Location: Inverness Posts: 182 ![]() ![]() |
many thanks - in the end took a chance and went with it as was - good news is passed and no advisories so a very happy chappie |
