Home > Wheels & Tyres > Pirellis or Michelin |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
In an ideal world I'd have thrown 4 AT's on, but as I have just started up by myself, parting with £600, was more than I could bare! However I would say that there is no way on earth You'd get me driving a car with the AT's on the front and Pirelli's on the rear. At least I've got the super grippy tires on the front!
11th Nov 2014 10:13pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2269 |
Agree with that |
11th Nov 2014 10:24pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7968 |
Really ! AT's & Pirellis are so different it could be scary. Most advice I've ever seen is that you put the grippy tyres on the back - the rationale is that the vast majority of drivers can react to understeer way better than they can handle oversteer. Not a very hairy chested macho opinion, but most likely true. I'd rather buy part worn tyres than mix them to that extreme..... |
11th Nov 2014 10:48pm |
Understeer is for poofs! I was brought up on oversteer, MGBGT V8 the dogs in the dry and the scariest but fun thing in the wet, especially when I put Michelin's on the back, power slide all the way baby
11th Nov 2014 11:17pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Oversteer in a FF Whatever next!
11th Nov 2014 11:33pm |
Must admit your right there Craig, especially when you look at what I'm driving, not exactly a fire breather. That's why I've got the grippy tires on the front, under steer is a real possibility, but over steer, you'd need cast iron underpants just to try it Yesterday I couldn't spell Engineer... Today I are one!
11th Nov 2014 11:54pm |
salb Member Since: 25 Feb 2012 Location: blackburn Posts: 332 |
FFRR, oversteer/understeer...............
12th Nov 2014 6:16am |
mylife1903 Member Since: 11 Nov 2014 Location: siberia Posts: 1 |
hi all
12th Nov 2014 6:54am |
salb different tires do make a difference to the handling of a vehicle. Some tires are of a soft compound which sticks to the road like glue, but wear out a lot quicker than a hard tyre. The trick is to find the right compromise. And that is before you go in to the the in's and out's of which type of tread to use, the more off road like the tyre is, the less rubber you have in contact with the ground.
12th Nov 2014 10:58am |
alx Member Since: 13 Jul 2014 Location: Beds Posts: 99 |
I'm going to throw a spanner in the works with a... Yokohama Advan S.T. vote.
21st Nov 2014 2:02pm |
wackyjim Member Since: 11 Aug 2010 Location: Brigadoon Posts: 2015 |
^ Had Advans on my Audi S8 terrific tyre but boy they don't last long especially if you drive like a hooligan!! The forums premier drug dealer and human trafficking consultant
21st Nov 2014 2:25pm |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2587 |
We have a 90 degree left hander at the bottom of our hill, due to weather, camber and surface no matter what tyres or condition of them, you can get spectacular oversteer if not careful or know what you are doing....gets the dog walkers thinking takes me back to my beetle days coming out of wet roundabouts on opposite lock, much more spectacular in the FF
21st Nov 2014 2:48pm |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 |
oversteer in a range rover?
21st Nov 2014 4:32pm |
Johnboy, I have had it a couple of times over the last 8 years and always on the same stretches of road, a bit disconcerting at first but easily caiught.All tyres good, no excessive speed etc. The roads it happens on are full of cars in fields when wet....ah bonny Scotland In fact on my road I probably tow 4 or 5 a year out of the ditches/fields. Its not the tyres |
21st Nov 2014 4:41pm |
