Home > Technical (L322) > What are these all about? |
MattChaloner Member Since: 12 Oct 2014 Location: Corsham, Wiltshire Posts: 52 |
19th Nov 2014 7:38pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
They look like old RR Sport HSE 19" wheels on the top one - not fullfat wheels |
19th Nov 2014 8:26pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3979 |
They are stuck on with a double sided tape running all round the edges.
19th Nov 2014 8:40pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8662 |
So not riveted on then, but the grilles still a pain.
19th Nov 2014 9:02pm |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
I saw a RR close to me for sale but it had those side things on, put me off the car to be honest as like said above i was worried how hard they would be to get off and if there covering anything up |
20th Nov 2014 8:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Make sure the paint around them is original too... Seen body shops mask around them and paint the lower section of the door... So, if you removed them you would be left with a bit of a mare sir |
20th Nov 2014 9:06am |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 |
The side strips are stick on and are the same as the ones I had on my D3. They were also the same part # for the RRS. If you position them right, they will stop car park dings from other peoples' doors. They will also, in my experience, eventually peel off. I went through 2 sets. They don't peel paint when they come off, but they do leave a lot of difficult to remove glue from the double-sided tape.
20th Nov 2014 1:24pm |
