![]() | Home > Maintenance & Mods (L322) > Starting problem |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Sounds like it's not recognising its in park, maybe the gearbox selector cable cable has gotten a bit lazy, and needs a good shot of lube. Have a search there are threads on how to, nice and easy. There is nothing that can't be fixed with a hammer😜😜
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8541 ![]() ![]() ![]() |
Could be, or possibly, the inhibitor switch that makes it possible to only start in park or neutral... Pete
Beanoraa Member Since: 27 Aug 2012 Location: N Ireland Posts: 18 ![]() ![]() ![]() |
Thanks guys will look into those suggestions |
Hi guys thanks for the replys sprayed gear linkage with wd40 and then greased it seems to have done the trick. A cheap and easy fix for once happy days |
Glad it's sorted👍 There is nothing that can't be fixed with a hammer😜😜
