Home > Technical (L322) > LED lights flicker while lights off |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Quick question guys to ones who have fitted LED's to the side lights.
18th Nov 2014 6:22pm |
18th Nov 2014 6:47pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Mine do .
18th Nov 2014 6:49pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
if you have an IIDTOOL then you could switch off the hot & cold monitoring, hopefully this will stop the flickering when off... ... - .- -.
18th Nov 2014 6:51pm |
Thanks guys, now how to find the hot/cold monitoring with my iid tool.
18th Nov 2014 7:02pm |
No WD, mine don't flicker when switch off and engine running. |
18th Nov 2014 7:03pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8069 |
Tried to turn the cold monitoring off on mine but you can't turn it off for the sidelights... most other bulbs you can.. Pete
^ oh br
18th Nov 2014 7:07pm |
Worth having a look, it's in the CCF settings... I turned off all the ones I could and mine flicker 10 times on startup but I haven't noticed them flicker at other times but it could be I've never noticed!!!! Pete
18th Nov 2014 7:10pm |
i think you're right Pete, i've looked on the GAP site and the sidelights dont seem to be listed.. ... - .- -.
18th Nov 2014 7:13pm |
Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804 |
Yep, that was my post from Landyzone, my LED Bulbs flicker, both side lights and fog lights, they flicker for about five seconds on startup and when engine running and lights switched off.
18th Nov 2014 8:57pm |
Well just had reply to my email ( who I bought them from) asking if the led's might be faulty or is the flickering normal on retro fit....reply back was 'do you want exchange?'
21st Nov 2014 4:09pm |
They seem very busy WD and this seems to be their polite way of buying themselves a little time, keeping your plate spinning whilst they then deal with other business. I suppose they could have said "Sorry, but ... "
21st Nov 2014 5:39pm |
