Home > Off Topic > Blue screen of death |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 |
Bah humbug |
11th Nov 2014 10:28pm |
Unnecessary quote removed
11th Nov 2014 10:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8637 |
Log fires
11th Nov 2014 10:44pm |
BSOD is easy to fix if you're patient. Take a photo of the BSOD and note the faulting module and the error number. Then google it. The chances of you having one which google doesn't have the answer for are remote indeed but even if you do, just re-installing the OS will likely fix it.
12th Nov 2014 8:00am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35383 |
i'm in the 'hate xmas' club.... ... - .- -.
12th Nov 2014 8:14am |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3697 |
12th Nov 2014 8:48am |
nobbyclark Member Since: 16 Sep 2014 Location: Cumbria Posts: 131 |
Back OT, BSODs are usually because a driver needs updating to support new hardware or because a new driver has been installed that is incompatible with existing hardware. As already mentioned, there is actually a lot of useful info (for us geeks) in the BSOD that will help to diagnose it. The screen usually displays the offending file (something.SYS), the error (in CAPS with underscores e.g. YOU_ARE_STUFFED) and at the bottom a Stop code beginning "0x". Use your favourite search engine to look for the error code or stop code and you will usually find someone who has gone through the same pain and hopefully posted a fix. |
14th Nov 2014 9:55am |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
14th Nov 2014 2:44pm |
I've often found a good spinrite at level 4 does the trick and staves off bsod issues until the drive is swapped or machine rebuilt FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
15th Nov 2014 12:27am |
