Home > Technical (L322) > Timing Chain replacement/Engine Out
Page 3 of 4 <1234>
Mikey
Would be replacing the oil feed pipe as matter of course. An extra £90 or so, but will save you 2 turbos in the long run Thumbs Up
Post #290737 4th Nov 2014 8:32pm
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
northernmonkeyjones wrote:
Not at all implying that you should chuck money at it if not needed, but as oil starvation is one of the main causes of turbo failure (caused partially by improper servicing) aside from egr issues, i would definitely get them to check that the turbo oil feed pipes are clear and not blocked, could probably be cleaned out if needed too so only a small cost involved, and as the turbos are off the car and the engine then should be easy and pretty much par for the course when they are putting it back together. Thumbs Up
The Turbos/EGR, etc... are not out of the engine. Look at the first pics. The only thing that is out are the necessary parts to reach the valve covers, intake manifold/plenum chambers, and the sump of the engine. Everything else will be staying on. I'm planning the next visit tomorrow or thursday and I will see what can be done at minimal cost regarding the turbos.
Post #290781 4th Nov 2014 10:16pm
Ziggy
Australia
Cobber it might be hard finding the bucks now but it will be a lot harder finding the thousands if something stuffs up that could have been prevented while the motors out, its a lot eraser to get at everything now than when its back in the car...........a stich in time saves nine ...........and checking and cleaning wont cost that much
Zigg "Those who cannot remember the past are condemned to repeat it."
George Santayana
Puts away his cloth cap and donkey jacket
Goes and sits in the naughty corner
Post #290929 5th Nov 2014 1:04pm
I think it's too a budget because VMPP might be selling the car soon rather than a shortage of funds.
Post #290932 5th Nov 2014 1:25pm
VMPP
Mr. Green
the sale of the car is always on top of the table....
Just need mr right...
Post #291026 5th Nov 2014 8:00pm
VMPP
So, the parts have been replaced.
The tensioner was ok. Seems that one of the guide's plastic covers has unglued itself, hence flapping around and the ffff fffff ffff noise.
The Valve cover has already been mounted.
The engine will be ready to go into place during this week.
I will also replace the belts tensioner as it is making a bit of noise.
Other thing which will be replaced is the thermostat housing, as they are prone to crack.
The car also needs new bushings in the trailing arms of the front suspension. Turns out LR no longer sells the bushings separately. Now we need to buy the whole arm!!!! 15€ vs 250 € Censored Censored
I found some bushings on the island4x4 website, so problem sorted...
Post #292037 10th Nov 2014 6:10pm
johnboyairey
wow, seems incredible to think they are bonded, and not clipped, or pinned. the heat and temp change, in all that oil is asking for long term failure. good diagnosis/spot at early stage, and no catatrophes. (yet) good pics too.
Post #292043 10th Nov 2014 6:40pm
VMPP
Engine getting ready to go back to it's place.
Post #292275 11th Nov 2014 7:30pm
Ziggy
Australia
That was a big job cobber, I hope it all works when you turn the key, would be great to have a vid of the first run
George Santayana
Post #292853 14th Nov 2014 6:16am
ebajema
Looking great mate and I hope that it all works out well for you, no matter what you do, sell, keep etc. Please keep the pics coming though, I for one am very interested in the progress and outcome. MY 2010 5.0 SC Galway green and sand interior!!
Post #292856 14th Nov 2014 6:37am
VMPP
Post #292981 14th Nov 2014 3:57pm
Ziggy
Australia
Any up dates is it running cobber
George Santayana
Post #294812 22nd Nov 2014 9:57pm
VMPP
News!
Engine back in it's, hopefully for a long time, final resting place.
Just getting the finishing touches done.
My eyes are already misting up, just thinking in the bill that I will be presented....
Whistle
Post #295016 24th Nov 2014 6:30pm
Sandyt
Don't look at the bill listen to that sweet engine well done Thumbs Up Thumbs Up
Post #295022 24th Nov 2014 7:07pm
how many bolts do you have left over? Mr. Green ... - .- -.
Post #295026 24th Nov 2014 7:27pm
Page 3 of 4 <1234>
