Home > Technical (L322) > Park Brake Error
Vorbis
United Kingdom 2007 Range Rover Vogue SE TDV8 Santorini Black
Park Brake Error
Got in this morning and the handbrake wouldn't disengage immediately. It did after about 20 seconds or so but I had a warning light and a park brake error message. Turned the engine off, restarted and the error and warning light disappeared. Worked fine this evening with no problems and no errors.
Is this just a glitch in the matrix or something to be concerned about?
Post #292830 13th Nov 2014 10:15pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
on L322 you can start them handbrake pushed down at time of starting to clear park brake faults/seized on etc. Cheers
James
Post #292832 13th Nov 2014 10:34pm
noworries4x4
Could be a low battery voltage when cranking causing this fault, I had it the other week after leaving the radio on to long. If everything is under control you are not going fast enough.
MY 16 Discovery 4 Commercial Workshop and Escort Vehicle
MY 12 Full Fat TDV8
1952 Series 1 80" 3ltr 6cyl
Post #292837 13th Nov 2014 11:17pm
Vorbis
Thanks for the help. Hasn't happened since, so keeping things crossed
Post #292996 14th Nov 2014 6:09pm
