Home > General (L405) > Door lock malfunction |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35329 |
you were lucky that the fault occurred whilst you had the opportunity to prove it to a technician, most times the fault doesnt show when you are at the dealer so i recommend making a video to show the techs..
11th Nov 2014 11:58am |
CharlesA22 Member Since: 08 Jan 2014 Location: Strathclyde Posts: 33 |
I had supplied the attached photograph showing the impossible situation of the "Locked" door opened from the outside but with the "locked" light still illuminated. They concluded this was "normal" behaviour after checking on an "identical" vehicle. If this is truly the case then my vehicle may not be the only DANGEROUS Range Rover out there!! I'll make them a video next time as you suggest. Pity a video can't record some of the other recurrent defects on my car like the FBH smell! FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024 |
11th Nov 2014 12:20pm |
when i had my td6 i found if i parked a certain way the wind would blow the fbh fumes into the air duct system, could this be your problem? ... - .- -.
11th Nov 2014 1:16pm |
Thanks for that Stan but this is a specific issue caused by the repositioning of the FBH on the L405 which resulted in the exhaust pipe discharging toward the transmission tunnel area. (i.e. closer to the passenger compartment). This defect of design has been the topic covered in Thread "Smell of fumes from 4.4 SDV8 when driving slowly" on this site. FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024 |
11th Nov 2014 2:47pm |
you'd think that when they did the R & D on the l405 that they would have come across this problem and sorted it out... ... - .- -.
11th Nov 2014 3:06pm |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3097 |
I notice that you're in Strathclyde, just out of interest, which local dealer are you using?
12th Nov 2014 12:42am |
Taggarts Glasgow North FFRR user since 1974. RR No. 10 (2021MY P525 AB delivered Nov 2020) Gone. No 11. P550e AB MY2024 delivered June 2024 |
24th Nov 2014 2:18am |
Unnecessary quote removed
24th Nov 2014 3:19am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Good luck with it Charles... Fingers crossed sir |
24th Nov 2014 9:21am |
