Home > Maintenance & Mods (L322) > Time to check your battery!
Have two 100Ah bosch batteries in the garage which have just been on the cetek so could chuck one of them in for the time being!
One was the battery I thought was scoobied by the alternator, but seemed to recon ok on the charger. Very Happy There is nothing that can't be fixed with a hammer😜😜
Post #291695 8th Nov 2014 9:29pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
Good luck but keep an eye on it. It may charge but if it has been badly discharged in the past the plates may have buckled and it may not hold the charge. Hope that's not the case. The recon may have sorted it Thumbs Up 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #291707 8th Nov 2014 9:59pm
NMJ, an idea but you could hook up one of the batteries temporarily to the boot area and then just remove the one from the front. As long as you dont start or try to run any electrical systems and insulate both battery clamps at the front it would save you losing the settings on any of the onboard stuff Smile You could leave the battery in the car and just disconnect the leads and cover them so they dont touch anything, easier than yanking it out again and the heat given off the battery tray area can more than deal with Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #291715 8th Nov 2014 10:28pm
Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #291746 9th Nov 2014 8:16am
andyleeds
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
how long should these bosch battery's last, mine has just failed me but i am sure its only a couple of years old?
also can anyone recommend any of the following?
trickle charger / battery conditioner?
jump starter?
cheers
Post #292959 14th Nov 2014 2:31pm
my bosch 020 failed after 11 months, ECP replaced with any problems... ... - .- -.
Post #292968 14th Nov 2014 3:04pm
andyleeds
mmm i will have to see if i still have the receipt..... was it just not holding charge stan?
Post #292978 14th Nov 2014 3:49pm
it started to get sluggish on startup and when checked with a multimeter it was below 12 volts.... ... - .- -.
Post #292980 14th Nov 2014 3:56pm
Charmer
My Bosch S020 only lasted 18 months. Again ECP replaced without question, you will need your receipt I would have thought.
I would recommend CTEK battery chargers.
Post #292983 14th Nov 2014 3:58pm
andyleeds
i think a ctek charger might be a good idea as i have the tow bar electrics..... does a mulitimeter show what you need to see as isn't it about what it does when its under load?
Post #292989 14th Nov 2014 4:16pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
so where would be the best place to purchase a new batt..
I keep getting HDC inactive, although my 65 mile drive should be bringing the batt back to full spec every day. I suspect if has lost some retention of charge now (it is 3 1/2 years old)
Tayna will look at warranty for me (it has 5 yrs) but it involves sending them the batt first (so I will not have a car) before they tell me if it's knackered. If it is they will send me a new one but the new one will only have the remaining portion of the 5 yrs warranty (i.e. 18 months). That seems a bit strange but so be it.
Just wondering if i should just go and buy a new one somewhere else. Any deals out there....?
Cheers Ash
2016 SDV8 AB
Post #298525 12th Dec 2014 7:59am
JPS
2005 Range Rover Autobiography Td6 Zambezi Silver
I recently purchased a Bosch S50 battery from Euro car parts and it was £114 delivered. Has been great on these cold mornings and the car can stand a few days and then fire up on the button no problem. Thumbs Up
Post #299064 15th Dec 2014 1:40pm
Battery Megastore is the cheapest after you Like them on facebook and follow them IIRC Smile I also downloaded their app which brought the price down even more Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #299067 15th Dec 2014 1:54pm
