Home > General > TDV8 3.6 L322 First Time Buyer Query |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8649 |
That's a fair list of questions there, have a search on here and most of the answers will be out there.
5th Nov 2014 10:25pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
That's a big list...
5th Nov 2014 10:29pm |
I believe the part is about £300, but it's a dash apart job to fit it, whch is doable if you are handy with the spanners or probably at least 150 at a dealer. There is nothing that can't be fixed with a hammer😜😜
5th Nov 2014 10:45pm |
You do take a couple of dash bits out but being LR it's 90% plug n play with a couplr of broken clips on the way....couple of hours later and Neil Diamond is playing through the dreadfully under specified 'logic7' !! Is this where I put the car details and a bit about myself ?........ |
5th Nov 2014 10:48pm |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 |
Cheers for the replies .
6th Nov 2014 12:00am |
you keep the changer, there is a switch on the control box that switches from changer to ipod Is this where I put the car details and a bit about myself ?........ |
6th Nov 2014 12:17am |
Googsy Member Since: 02 Jun 2011 Location: Where men are men and sheep are nervous. Posts: 2947 |
Hi Stephen car dealer in Stillorgan by chance?
6th Nov 2014 12:40am |
Thats the one conor. Had a good look over it the other day, proce is a little higher than id want but the spec cant be beat. Theres a little rust under the rear arches but im going to ask to have that sorted , a new decent battery and the alternator and gearbox / diff fluid done. Must double check the suspension arms too |
6th Nov 2014 12:51am |
