![]() | Home > Wheels & Tyres > Leaking Rims |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1259 ![]() ![]() ![]() |
Just had some new tyres fitted on the front wheels (255/55 19 Goodyear Wranglers) on our 2003 L322 and the front nearside is losing pressure.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
make sure its not a crack in the rim itself and if you are sure thats ok then the tyre seal stuff will be ok.. ... - .- -.
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
When I have had similar problems I have asked the fitter to refit the tyre - usually they did not clean up the old rim properly. They have usually done this for free.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Put the spare on.......
Our tyre fitters down the road clean the rims up with a wire wheel attachment on an air drill if there is any sign of corrosion! Id take it back and ask them to do the job properly this time... |
I must admit to being a bit surprised about this as,we have used this tyre dealers exclusively for years.
Did you want your wheels refirbed before you fitted new tyres Paul? Doesn't make sense to have them done because the tyre fitters didn't do their job correctly sir!
