![]() | Home > Off Topic - Other Cars > Create A Bow Wave When Crossing Water |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7906 ![]() ![]() ![]() |
Joking aside, I am told that the limiting factor nowadays is that the cars tend to start to float and then lose traction. 2011 Range Rover Vogue SE 4.4 TDV8 Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Winch em out, open the doors, take the injectors out, crank a little,...refit injectors.......start her up and away you go.....to the next little puddle |
He just needs to extend his snorkel a bit and take a longer run up.... |
As someone who was had water hitting the passenger side of my FF half way up the windscreen thanks to the flow of water being on that side i can say they are VERY water tight but if you expose the scuttle to more than a few seconds of water the interior WILL be soaked!
