Home > Off Topic - Photos and Video > One for the Techie Guys on here
Eldest daughter had taken pictures on her phone when our granddaughter was born 6 weeks ago ... So she is a bit distressed at maybe losing them all together ...
So thought i would ask on here first as i know a few of you are more knowledgeable on this stuff than me ...
Problem is most of them will not open after being downloaded to her PC as it keeps saying file is corrupted preview cannot open ...
Does anyone know or used any of these jpeg software file repair companies that are on the net ...
Or can anyone recommend a decent repair one ...
TIA Thumbs Up
Post #289757 30th Oct 2014 12:33pm
stcstc31
Ireland 2005 Range Rover SE Td6 Atacama Sand
try sending them up to dropbox and downloading from there, could be just thr transfer to pc has screwed em
Post #289758 30th Oct 2014 12:47pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
The most likely cause is the memory card itself becoming corrupt. In which case I doubt software would help you and may even make matters worse but interrogating an already failing memory card.
Do the photos display alright on the camera?
If so the problem corruption most likely lies in either...
1. The transfer method of the pictures to PC - you could try a different reader / usb connection maybe even to a different computer
2. The computer hard drive becoming corrupt
If the photos do not display on the camera then it is likely the camera memory card has become corrupt.
In any case - if the photos are really valuable then, until recovery takes place immediately ...
1. Do not continue to use that memory for more photos - it may be the only place that photos may be recovered from
2. Do not use the computer - it may be the only place the photos are recoverable from
Do not install software on the computer with photos - use a different computer otherwise you risk over writing photos. Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #289759 30th Oct 2014 12:49pm
The photos do not display on her phone ... Oh well looks like the pictures are ta ta Rolling Eyes
Saying that there are other pictures on it that have downloaded okay .... Shocked
Post #289760 30th Oct 2014 12:58pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Just a thought. Try connecting the phone to the PC via a USB cable and accessing the phone storage directly. I'm assuming that its an iPhone which does not have a removable storage card.
If you can find the images on the phone's internal storage you may be able to copy them directly from the phone to the PC hard drive.
But if you say that you cant view them on the phone then looks like the phone has corrupted them.
Post #289764 30th Oct 2014 1:26pm
It's an android phone with removable card , daughter hates iPhone Whistle
Post #289765 30th Oct 2014 1:32pm
PaulTyrer
Good for her!!
OK in that case you could try getting hold of a micro SD card reader and try to copy the image files directly from the SD card rather than using the phone / PC connected via USB, or the phone sync software.
As an aside, I never use the phone or camera copy by USB cable when downloading images from either camera or phone, I always use the SD / CF card reader, or the SD card slot on my laptop.
Another good idea is always have a couple of spare SD cards for either camera or phone as they can become corrupted, and ALWAYS back up your images to a PC hard drive AND an external drive!!
Post #289766 30th Oct 2014 1:46pm
Thumbs Up Cheers Paul , found a program that hopefully might work .... Thumbs Up
Post #289784 30th Oct 2014 4:13pm
Is the card full?
Sometimes you can get errors like that when its getting over 85% full.
never a good idea to fill the things really as it doesn't leave much wiggle room for error correction Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #289788 30th Oct 2014 4:49pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
I have a Galaxy S4 - whenever I take a photo it stores it online too (or atleast did until I disabled it)
Try checking that out.
Post #289795 30th Oct 2014 5:31pm
RR2008HSE
Good suggestions. What about emailing or texting the photos to another phone or computer that is known to be working.
Could also try googling file recovery software. I've not done it, so I don't have a programme I can recommend.
Post #289899 31st Oct 2014 1:09am
