Home > Maintenance & Mods (L322) > Swapping Reversing Camera
supershuttle
Well, although it worked left and right were transposed and no yellow lines. Craig advised me that the only fix was to swap the camera which I did and all is now good, even better for me was that you do not have to remove the rear spoiler to change the camera - my track record here is not good Embarassed
I got the replacement off eBay and it came with wire and camera holder should anyone be in need.
I do have a small question the camera looks as if it will come apart (4 screws) has anyone been inside one and if so can it be fixed. Geoff
Post #289567 29th Oct 2014 3:07pm
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi Geoff
I just took out the inside plastic top peace and see all kind of stuff, but cannot see a way to remove the camera without removing the rear spoiler.
My camera has a life of it's own sometimes. How did you replace the cam?
Post #289568 29th Oct 2014 3:17pm
supershuttle
It's different from my 2007, all I did was slide a thin blade each side of the camera and it just pops forward out of he holder. Geoff
Post #289571 29th Oct 2014 3:26pm
Robert
Mine is an 07 and this is the cam, is that different from yours?
Thanks!
Post #289576 29th Oct 2014 3:44pm
supershuttle
The 2010 just clips into the holder which is fixed in place with a rivet. I think the 2007 was all one piece, I just replaced mine with one I bought on eBay cut and spliced the wiring loom and fastened the new camera in place with double sided tape. Geoff
Post #289585 29th Oct 2014 4:48pm
Robert
Post #289587 29th Oct 2014 4:57pm
