Home > Maintenance & Mods (L322) > Heater
quabba
Scotland 2005 Range Rover Autobiography 4.4 V8 Java Black
Heater
Frosty this morning in sunny Scotland and today had to be the day I find out that the heater isn't working.
It blows out cold air ok Evil or Very Mad but no warm air no matter what temp setting I use.
I've tried it with the ac off and on.
Any help appreciated
Post #289509 29th Oct 2014 8:14am
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
faulty thermostat? Airlock in cooling system? loss of coolant? leaky radiator?
Post #289519 29th Oct 2014 9:30am
quabba
Checked the coolant level and pipes. They all look fine. No obvious leaks on radiator.
I'm also thinking it's the thermostat, is this an easy fix?
Post #289725 30th Oct 2014 10:24am
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
Does the engine get up to temperature ok? Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #289727 30th Oct 2014 10:31am
quabba
Yeah, engine heats up as normal.
Post #289734 30th Oct 2014 10:51am
Dolphinboy
Thermostat should be straight forward swap. There are also a couple of flaps/valves which can get stuck and not release the flow to the heater matrix. They are down near the wings somewhere (the posts are on here somewhere but cant give link as they are on my home computer.)
Do a search using + before each search term
Post #289755 30th Oct 2014 12:25pm
quabba
Bit of an update, blows out hot from windscreen blower and from feet and back seat blowers, only cold from front facing blower. Dial underneath vent makes no difference
Post #291362 7th Nov 2014 9:22am
Dolphinboy
deffo stuck flap i centre I reckon. U need to get in there and check for crud around the flap.
Post #291375 7th Nov 2014 11:22am
SMUTT
"U need to get in there and check for crud around the flap."
Depending on which Night Clubs you got to - it is probably not the first time that phrase has been used
... Rolling with laughter Howard
Post #291380 7th Nov 2014 11:33am
quabba
Post #291400 7th Nov 2014 1:07pm
