![]() | Home > General > The best car in the world |
Hey fella,
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3193 ![]() ![]() |
Hi dan, couldn't really tell if it had dropped or not - couldn't remember if I had left it on access level or not. The EAS button light and Air Susp warning came on then went off. Tested all the levels and they all worked fine. Yep, still looking for a box but needs to be a long one so I can get 2.10 length skis in.
I have a Thule Evolution 500, it should be long enough: http://www.tettontrailers.co.uk/roofboxes/...ution.html 315 litres, 226cm x 55cm x 37cm You can fit in a Ski Carier too apparently. There is a roof rail kit here: http://cgi.ebay.co.uk/Range-Rover-Roof-Rai...230a439330 ![]() |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2942 ![]() ![]() ![]() |
Mine was sat at Birmingham Airport for 16 days and it started up no problems this morning! Well Impressed! Even the back tyre, which has a very slow puncture, stayed up so I was able to drive home without having to stop off at a garage to blow it up. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35463 ![]() ![]() |
i was wondering how your FFRR would be when you came back..good result then noddy..so its back to the grind after [i assume] a very relaxing break... ... - .- -.
