![]() | Home > Off Topic > How Hard is it |
Mick, I'm with you. I'm finally getting my 18mm spanner into the non-shiny condition that my 17mm and 19mm ones are in with all the 18mm nuts & bolts on this crappy Skoda of mine.
Heres me thinking this was a post on viagra |
Errr...
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1258 ![]() ![]() ![]() |
Cant you get the 19mm deep one and either.. a) stick a 1mm shim down the socket or b) Grind 1mm off the end? ![]() |
WTF are you going to do with an 18mm deep 3/8 socket? |
@ NDF .. Checked them out earlier they told me 3-5 days delivery .... needed asap
To put you in the picture
Can't disclose that on here Jim .... |
Well it's certainly not his nuts, no way are they big enough to fill an 18mm socket ![]() ![]() I'll go out to the garage and have a look Mick, would a 1/2" drive be of any use if I have one? I can supply a 1/2" ratchet or breaker bar or T-bar also |
My dad used to have a full set of box spanners that you could tighten up with a T bar, probably about as much help here as a chocolate fire guard though! |
Cheers John , will let you know my Son is going to call up later with some concoction he has come up with regarding spanners ....
This any good fannybaws?
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6740 ![]() ![]() ![]() |
I'm just wondering if the extending wheel brace doesn't have an 18mm end? Got - 2017 SDV8 Autobiography in Loire Blue
