Home > Technical (L322) > Seatbelt issue
n1cktdv8
Seatbelt issue
My seatbelt isn't retracting to well on the driver side. Only recently started feeling slack....any ideas/fix ? Is this where I put the car details and a bit about myself ?........
Post #289081 26th Oct 2014 11:21pm
Nick A, take the B pillar trim off and see if the little silver strip that the seatbelt runs behind mucky? (rear sometimes gets sticky or corroded) stopping the seatbelt from sliding Thumbs Up
Or B, simply replace as the springs do get weak with time... (top tip), but a 2009> one as they are quite a lot cheaper and identical to the 2007-2009 seatbelt sir Thumbs Up
Post #289090 26th Oct 2014 11:52pm
n1cktdv8
I was just reading your post about replacing and cleaning as the labour involved isn't worth doubling the job...think will strip and clean + order a 2009>
As always Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #289092 26th Oct 2014 11:54pm
Thumbs Up Bow down Thumbs Up
Post #289093 26th Oct 2014 11:56pm
ahebron
New Zealand
Or try a bit of spray Pledge polish
http://forums.mg-rover.org/archive/index.php/t-355993.html
Adrian VW Amarok 2014 Highline auto
Post #289103 27th Oct 2014 5:36am
n1cktdv8
What's Pledge Whistle Is this where I put the car details and a bit about myself ?........
Post #289352 28th Oct 2014 1:26pm
Laughing furniture polish Nick... Wink ... - .- -.
Post #289353 28th Oct 2014 1:30pm
n1cktdv8
Is it Question Is this one of those moments when I then have to ask why we have a TV with a round screen in the utility room Rolling with laughter
Seatbelt service on all 5 belts underway.....no pledge am afraid, but some rather lovely smelling Wurth Lubricant !! Is this where I put the car details and a bit about myself ?........
Post #289355 28th Oct 2014 1:42pm
Nick, worth noting that the silver slider thingy Rolling Eyes Whistle that holds the belt (with two torxs bolts) turns around (incase it has corrosion on the rear) Thumbs Up
Post #289486 28th Oct 2014 11:53pm
hongkongphooey
Isle Of Man
Sorry to hijack the the thread, but not totally unrelated.
My drivers side front seat belt adjuster blocks started squeaking a bit. The only single noise inside an otherwise silent cabin, had it apart and liberally applied silicon spray, but still doing it.
Any suggestions Craig? Or just replace?
Cheers,
Phoney. Present* 2006 Santorini SC Vogue SE.
Gone* 2006 4.4 AJV8 Zermatt Vogue.
Gone* 2004 TD6 Bonatti Vogue.
Post #289961 31st Oct 2014 2:00pm
bishbosh10
Resurrecting and old thread, but can anyone confirm if any special precautions are required for a 2011 MY with regard to the airbag in the B pillar?
Do you just disconnect the battery or are there 87 hoops to jump through? Rolling Eyes
Reason I ask is my driver's belt is both lazy and starting to fray so a replacement is on the cards.
Thanks. Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #497871 7th Dec 2018 6:47pm
