![]() | Home > Technical (L322) > Timing Chain replacement/Engine Out |
I know the L322 was designed for different engines, but that is nuts. The old sport you had to take the body off to change a turbo. Such big cars with so little space to remove things. |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 ![]() ![]() ![]() |
The car has now 155000 kms, so roughly 100000 miles.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
I really wish you good luck with this and please keep the pic updates coming!!! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
yep, big job indeeeeeed! I changed the chain and tensioners on my 2002 bmw 4.4 v8 petrol. in situ, all with the front still on car, just rad out and rocker covers off etc. YES, you have to get that crank nut undone before you start all the 'easy' stuff. not difficult, as long as you have the engine timing tool (locking) set up 'kit'
No big news this week.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
Looks a lot more work than the old p38 you can whip a v8 out in just over a couple of hours good luck with it |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 390 ![]() ![]() |
Not sure on the 2007, but I had the chain tensioner update done on my 2011 SC and the engine did not have to come out.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
When we last did some work on a 4.4 tensioner there was something like 15 special tools needed! |
I posed that question also, but he told that indeed, on petrol models it can be done without a fuss. And it could also be done on this one, but it would be a crazy job, hence the engine out option. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Given its all stripped, it's probably worth checking the turbo oil feed pipes, turbos themselves for wear, and possibly getting the egr valves off and cleaning/replacing them. Also swapping all the turbo hoses etc. There is nothing that can't be fixed with a hammer๐๐
The last ''clean engine'' pics are not from mine.
Ziggy Member Since: 26 Dec 2011 Location: West midlands UK /sydney AU Posts: 265 ![]() ![]() |
G'Day VMPP
Yes it would be an almost like new engine.
Not at all implying that you should chuck money at it if not needed, but as oil starvation is one of the main causes of turbo failure (caused partially by improper servicing) aside from egr issues, i would definitely get them to check that the turbo oil feed pipes are clear and not blocked, could probably be cleaned out if needed too so only a small cost involved, and as the turbos are off the car and the engine then should be easy and pretty much par for the course when they are putting it back together. |
